YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Community > Check Out My Truck > Trucks, 3rd gen-'89 to '95
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-04-2008, 11:32 AM   #1 (permalink)
91 Truck Oil Change and Turn Signal Question
FYI: I have never done any auto repair in my life
1) I would like to change my own oil and replace my oil filter on my 91 pickup. IS this something someone with little to no knowledge could handle?
2) My left turn signals do not appear to be working and the arrow is clicking faster than normal. I tried checking the fuse by checking the turn signal fuse on the panel to the lower left of the steering wheel and that did not seem to fix the problem. Is it possible that a bulb could cause both signals to stop working? Did i check the wrong fuse? I did not check the fuses located under the hood and behind the panel beneath the glove box.
Any tips and or suggestions any of you can provide would be most appreciated.
Also, one more question. When I bought the truck I received a recall for the steering column that had not been replaced yet. Is the bunk steering column an immediate threat to my driving safety? Is it safe to do light off-roading (rough trails) without replacing the steering column?
bge187 is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Turn signal, hazards not working question. Shoxg711 General Electrical & Lighting Related Topics 19 02-26-2008 07:34 AM
WTB: Corner and Turn signal lights 87 Truck Chrome 2wd DeathCougar Items Wanted 1 07-19-2007 09:16 AM
90-95 truck/runner front turn signal lamps Arnold Items Wanted 1 02-25-2006 08:54 AM
LED Turn Signal Question ATP4984 95.5-2004 Tacomas & 96-2002 4Runners 6 11-09-2004 04:06 AM
Front Turn Signal Power Question LSUMatt1514 95.5-2004 Tacomas & 96-2002 4Runners 3 10-14-2004 11:07 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
