Gerdo's Profile. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Community > Check Out My Truck (No one can answer you in this section) > 4Runners-3rd gen
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-11-2006, 07:39 AM   #1 (permalink)
Gerdo's Avatar
Gerdo's Profile.
I've just starting to get my 2000 4Runner modified. It will be mild. Enough to enhance it's offroad capability and set it apart from the mall runners.
As mentioned, don't post in this profile!!!!
If you have any questions, just PM me.
__________________
2000 4Runner Sport, 3.4L, 5 Speed, Custom Front Winch Bumper, Opened intake, K&N Airfilter, BFG A/T LT265/70R16, Bilstein Shocks, FreeFlow Exhaust, Poly Rack Mounts & Swaybar Mounts, Tundra TRDs up front and OME 891s out back. ToyTec Panhard Bar Drop. SS Front Diff Drop. Home-built 2x2 Sliders. ARB rear locker, OBA, CO2 See My 4Runner!
Gerdo is offline
Old 05-12-2006, 12:51 PM   #2 (permalink)
Gerdo's Avatar
Well I put my mild lift on today. TRD coils up front (no spacers) and OME 890s out back. Here is a before and after picture. I got ~2" up front and 3.25" out back. The rear was sagging quite a bit. I know they will settle some still.
Before
After
Specs: Tundra TRD Coils. Left, 48131-AF100 (Yellow/Yellow). Right, 48131-AF090 (Blue/Yellow) Old Man Emu 890 Rear Coils. (A Coil goes on drivers side) Shocks: Front, Bilstein F4-BE5-2450-HO. Rear, Bilstein F4-BE5-2451-HO. (Yellow Body and Blue Boot) I reused my Bilsteins because they are still in good condition. I like the ride. I bought the springs from http://www.trdparts4u.com/
SS Front Diff Drip. http://www.sonoransteel.com/
I also installed Poly swaybar bushings from http://www.wheelersoffroad.com/4runswaykit.htm . And rear swaybar end bushings from AutoZone.
__________________
Gerdo is offline
Old 12-29-2006, 02:53 PM   #3 (permalink)
Gerdo's Avatar
A couple of shots wheeling.
__________________
Gerdo is offline
Old 12-30-2006, 10:05 AM   #4 (permalink)
Gerdo's Avatar
__________________
Gerdo is offline
Old 01-31-2007, 05:37 PM   #5 (permalink)
Gerdo's Avatar
I took some pictures. They arn't pretty but that's not what were looking at. Just a reminder, I have Tundra TRDs up front and OME 890s out back. I don't have any extra spacers, just the springs for lift.All measurements were made from the bottom of the flair to the center of my wheel cap. Unloaded the measurement was: Front 22.25" ,Rear 23". All other measurements will reflect a drop or rise from these measurements. I added 35# sandbags to my rear bumper for weight. This was as close as I could get to hitch weight.
Unloaded the measurement was: Front 22.25", Rear 23".
Loaded with +210 lbs: Front no change, Rear drop of .5"
Loaded with +315 lbs: Front rise of .25", Rear drop of .75"
Loaded with +420 lbs: Front rise of .25", Rear drop of .1.25"
Loaded with +560 lbs: Front rise of .5", Rear drop of 1.75"
This is 560 lbs of sandbags. This is the placement for this test.
My setup in by no means harsh nor is it squishy when loaded or unloaded. My ride was more harsh with the stock spring/shock combo. Stock I had Tokicos, I replaced them with Bilsteins which gave me a firm supple ride. I was still hitting my bumpstops and Jounce Bumbers (rear overloads) I kept my Bilsteins with my new springs. Great ride. Shocks can have as much if not more effect than springs on how harsh a ride can be.
OME Info: "I am giving you the approximate lift heights, your exact amount of lift will vary slightly depending on the condition of your current springs. The front heights are respectively: 880=1.25", 881=1.75" & 882=2.25" and the rears are: 906=2.0", 890=2.75" & 891=3.0" . The 882's are not an ARB/ OME recommended fit, but our experience has shown that they work well with some applications. " (info given from 4X4 Connection)
__________________
Gerdo is offline
Old 02-22-2009, 08:38 AM   #6 (permalink)
Gerdo's Avatar
No pictures now but I replaced my 890s with 891s and gained about 3/4". Now I need to add a top out spacer to the front. The nose is a little low, too much rake.
__________________
Gerdo is offline
Tags
4runner, arb, be52451, bilstein, drop, f4be52450ho, f4be52451ho, gerdo, ome, rear, sandbags, weight, winch, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Phalanx's Profile Phalanx 4Runners-2nd gen 5 12-06-2006 08:44 PM
msw0085's profile msw0085 4Runners-3rd gen 0 12-16-2005 09:34 AM
flyAddict's Profile flyAddict 4Runners-4th gen 0 09-01-2005 06:16 AM
2009 InternetBrands, Inc.
