YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Community > 4ROC (4Runner Owner's Club) > 4ROC > Arizona
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-18-2008, 12:15 PM   #1 (permalink)
SOAZtim's Avatar
Thumbs up I need some help, 4runners hurt.
I think I need a third member quick.
There is a lot of friction in the rear end. It sounds and feels (vibration is shakes the whole car) like it is in the rear diff.
At just a couple miles an hour its harsh enough to halt the car and make a squeeking noise.
It would come on every couple of feet. About every revoltion of the tires.
The car will roll fine at idle speed in drive for a couple feet and then the rear end will bind up and bring it to a halt. I can overcome it by applying a little gas, but it doesn't feel good!
I rolled back and forth, in high 2wd, 4wd, low 4wd, center diff locked and unlocked and it does it in every scenario.
The weird part: after a bit I gave it some gas, okay a but much, and it stopped. Completely. No more grinding, no more noise, or vibration. No leaks even at the time.
Now today a leak has developed where the pumpkin bolts together.
All in all, its obviously not good. I need a new third member. Preferably elocked while I'm replacing it, but I'll take anything. This is my daily driver and I need to get to work.
__________________
Yotatech.com Oval Stickers FOR SALE HERE
2001 4runner. 255/85/16 Cooper ST's, DR coilovers, PP rear spring wit billies, 4.88's with Special magic front and rear.
www.soaztim.com
SOAZtim is offline
Sponsored Links
To remove this ad, register today!
Old 02-18-2008, 12:52 PM   #2 (permalink)
Staff
Elvota's Avatar
Sorry to hear this problem is still occurring.
I assume you are in Phoenix... or are you hung up in Tucson still?
Is there anyway it's anything to do with your brakes?
What about this idea. Pull your rear DS completely. Engage 4WD and see if things are still binding . Might give you another clue as to the source with zero engine load on the rear axle.
Just brainstorming.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
Elvota is online now
Old 02-18-2008, 12:54 PM   #3 (permalink)
Staff
Elvota's Avatar
By the way... I have a V6 3rd from my '90 with 4.56 gears sitting in my garage. If it will fit, and work for you... you are welcome to borrow it for a while.
__________________
Old 02-18-2008, 02:24 PM   #4 (permalink)
westy44runner's Avatar
Tim - check your PM's...and if you dont get over to TTORA soon check into this -
http://phoenix.craigslist.org/pts/532803138.html
Non-elocked 3rd gen 4runners have the regular Toy V6 8" diff.
__________________
'86 Toy Flatbed with a few modifications
westy44runner is offline
Old 02-18-2008, 03:28 PM   #5 (permalink)
SOAZtim's Avatar
I made it back from Tucson somehow. Did about 45 and I'd stop to check the rear diff a lot. It was hotter than I've felt it, but I just tightened a couple of the bolts and kept going...
Thanks westy. LM for him. "sonoran fabrication" was the number on the add.
Hmm. Is it Steve S evil twin...
Elvota, seems to just be in the axle. I got under there and turned the wheels with the axle off the ground. Its very quite now. Almost like I sheered teeth before and now it is just clunking waiting to fail... ?
__________________
www.soaztim.com
SOAZtim is offline
Old 02-18-2008, 03:57 PM   #6 (permalink)
Staff
Elvota's Avatar
Quote:
Well... it looks like my 4.56 V6 diff I have would work on your 4Runner if the E-locker on CL falls through.
Let me know and I can bring it over so you don't have to put any more miles on your time bomb.
__________________
Old 02-18-2008, 04:01 PM   #7 (permalink)
SOAZtim's Avatar
Just brainstorming.
Really! I wasn't totally sure it would. I guess as long as I was in 2wd it would work.
I'll do some searching/calling today and tonight to see what I can come up with and that may be the way to go.
__________________
www.soaztim.com
SOAZtim is offline
Old 02-18-2008, 04:33 PM   #8 (permalink)
wormhole's Avatar
Tim, check your mailbox.
I wonder though if this had something to do with it?
__________________
2000 Toyota 4runner auto, 4x4, elocker, budbuilt skid, Sonoran Steel 7.2, 265/75/16 Yokohoma Geolanders AT-S
Just call me "T"
Sold: 1996 Toyota 4runner, auto, 4x4, Bud Built front skid, Stubb Welding Sliders, SS #3, hella 500's and elocked rear axle
wormhole is offline
Old 02-18-2008, 04:34 PM   #9 (permalink)
Staff
Elvota's Avatar
Most likely the ratio won't do for 4WD, but in 2WD things should be fine. Do you have any idea what ratio your truck has now?
Actually... I wonder with auto hubs and the front diff is spinning all the time that a different rear ratio in the rear would cause problems?
If we can't be sure, we could pull the front DS to be safe. That would eliminate the possibility of the transfer case being "fed" 2 different ratios from the front and rear axles.
Maybe someone will chime in.
__________________
Old 02-18-2008, 07:23 PM   #10 (permalink)
Zona4r's Avatar
Tim,
are you running an extended rear diff breather? Maybe sucked some river muck in somehow with that crossing.
You should be running 4.10s. E-locked is 4.30s
__________________
97 4Runner SR5 3.4l auto e-locker
Zona4r is offline
Old 02-18-2008, 08:12 PM   #11 (permalink)
SOAZtim's Avatar
T, I'm not responding to you. That photo is photoshoped. I would never do that! haha! Just kidding.
Zona,
I do have an extended breather. I still may have sucked some in though.
It has 4.10's by the vin # chart I've looked up before.
__________________
www.soaztim.com
SOAZtim is offline
Old 02-18-2008, 08:16 PM   #12 (permalink)
wormhole's Avatar
__________________
Just call me "T"
wormhole is offline
Old 02-24-2008, 07:35 PM   #13 (permalink)
111db's Avatar
Send a message via MSN to 111db
Tim sorry to hear about this. What is the latest? Let me know if you need anything.
Here is some good toy diff info. Will let you know what will fit and what won't:
http://home.4x4wire.com/erik/diffs/
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 02-24-2008, 08:24 PM   #14 (permalink)
SOAZtim's Avatar
I've got some parts ordered. There will be a few fun nights taking the front and rear diff out.
I really want to get it up and running again soon...
__________________
www.soaztim.com
SOAZtim is offline
Old 02-27-2008, 10:43 PM   #15 (permalink)
SOAZtim's Avatar
Thanks to 111db for the extreme help, storage etc etc!!
Snagletooth.....
oops
mmm chunky
__________________
www.soaztim.com
SOAZtim is offline
Old 02-28-2008, 04:28 AM   #16 (permalink)
wormhole's Avatar
Dang, that might be a problem.
How was pulling the front and rear diff?
__________________
Just call me "T"
wormhole is offline
Old 02-28-2008, 07:07 AM   #17 (permalink)
SOAZtim's Avatar
Oh I don't know. A little JB weld and som puddy?
Hello gears.
__________________
www.soaztim.com
SOAZtim is offline
Old 02-28-2008, 07:58 AM   #18 (permalink)
111db's Avatar
I think we did pretty good: he pulled in the garage at 6pm and we had them both out by 8:15 or so.
__________________
Jon
111db is offline
