YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Community > 4ROC (4Runner Owner's Club) > 4ROC > Arizona
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-04-2008, 09:29 PM   #1 (permalink)
AZ4ME's Avatar
Elvis Carnage
Well here is what's left of the drive's side birf after blowing it on the J-turn on Elvis.
The break also managed to break loose an oil baffle that sits in the tube a couple inches inside the axle seal. Hopefully not having it won't cause too much more oil to leak into the knuckle. Steve recommended getting the Marlin HD seals next time I tear down the knuckles.
Anyway, the Long's are in and I should be good to go for some thrashing this weekend.
__________________
-Brian
'88 4Runner
'00 4Runner
AZ4ME is offline
Sponsored Links
To remove this ad, register today!
Old 03-04-2008, 09:33 PM   #2 (permalink)
wormhole's Avatar
I'm still surpised that you made it back with carange like that.
__________________
2000 Toyota 4runner auto, 4x4, elocker, budbuilt skid, Sonoran Steel 7.2, 265/75/16 Yokohoma Geolanders AT-S
Just call me "T"
Sold: 1996 Toyota 4runner, auto, 4x4, Bud Built front skid, Stubb Welding Sliders, SS #3, hella 500's and elocked rear axle
wormhole is offline
Old 03-05-2008, 08:38 AM   #3 (permalink)
Staff
Elvota's Avatar
Did you have to pull that to continue.... or just let it grind around in there until getting home? I have heard a blown birf can cause steering issues.
I 2nd the Marlin HD seals. I put them in with my longs. They are a quality part, and I haven't had any leaks.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
Elvota is offline
Old 03-05-2008, 08:48 AM   #4 (permalink)
westy44runner's Avatar
Nice carnage. You wont have to worry about that anymore with the Longs.
I can second the steering and birfields having a direct impact on each other. Although, breaking a birf probably has less an impact on the steering vs breaking knuckle studs which after driving less than a 1/4 mile left my inner knuckle ball and birfield damaged badly.
I dont have the Marlin HD seals but they are getting installed next time I tear down the knuckles. My knuckles both leak a bit and I even used the fish pull scale to align them. Word is that Marlin also has some new HD tcase seals coming out as well.
__________________
'86 Toy Flatbed with a few modifications
westy44runner is online now
Old 03-05-2008, 10:12 AM   #5 (permalink)
AZ4ME's Avatar
No I didn't have to pull it on the trail (thank god). I just unlocked the hubs and drove out the rest of the way in 2WD low. There was no grinding after that. Yes there was some steering issues. Making a very sharp right hand turn was not happening. I had to reverse sometimes to make the tighter turns.
Getting the blown birf out of the ball was fun also. One of the larger chunks you see in the pic was not completely broken off. It was cracked and had expanded the birf so it wouldn't fit coming out. I had to keep moving it all around and trying to knock the cracked piece back down with a BFH to pull it out.
__________________
-Brian
'88 4Runner
'00 4Runner
AZ4ME is offline
Old 03-05-2008, 10:38 AM   #6 (permalink)
AZ4ME's Avatar
Hey, quick question. Where does the gasket circled in red go? It comes with the knuckle service kits from TG. It has to do with the wheel bearings but I couldn't figure out where it would go. I didn't replace the wheel bearings, just repacked them.
__________________
-Brian
'88 4Runner
'00 4Runner
AZ4ME is offline
Old 03-05-2008, 10:40 AM   #7 (permalink)
Staff
Elvota's Avatar
I might not be the best one to answer that... as I always have parts left over from those service kits.
I am pretty sure I didn't use that particular gasket, but that's just from memory. It's possible that if everything was apart and across your garage floor that the mystery gasket would make sense.
__________________
Elvota is offline
Old 03-05-2008, 11:44 AM   #8 (permalink)
if its from TG, its probably better it doesnt get installed kinda...
I had/have a bunch of left over gaskets too...those kits always come with extra. Just follow the FSM
__________________
Old 03-05-2008, 01:23 PM   #9 (permalink)
AZ4ME's Avatar
Well, it's good to know I'm not the only one who doesn't know where the hell it goes. I guess it goes right in the trash then.
__________________
-Brian
'88 4Runner
'00 4Runner
AZ4ME is offline
Old 03-07-2008, 05:45 AM   #10 (permalink)
sschaefer3's Avatar
You use the round one and throw that one away.
__________________
Steve Schaefer
WWW.SonoranSteel.Com
Suspension Lift Kits * Rock Sliders * Straight Axle Conversions * 4Runner/FJC Rubicon Express Lower Links * Accessories * Daystar Products Dealer * TJM Bull Bar Dealer * Deaver Leaf Spring Dealer * Tokico & Bilstein Shock Dealer * ViAir Dealer * Total Chaos Dealer * and like everyone else a Trail Gear Dealer
sschaefer3 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Elvis & Upper Woodpeck AZ Yotatech Run 2/23/08 wormhole Trip-Trail Reports & Photos 22 02-29-2008 09:49 AM
Feb 23: Elvis, Upper & Lower Woodpecker: Casey & Charles from California will be here sschaefer3 Arizona 60 02-24-2008 03:06 PM
AZ - Elvis Trail westy44runner Trip-Trail Reports & Photos 25 03-15-2007 12:16 PM
Carnage 2-25 AxleIke Trip-Trail Reports & Photos 17 03-08-2006 03:20 PM
Elvis Cup of Water on Ebay ugadawg95 Off Topic Talk 2 12-27-2004 02:47 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
