YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Community > 4ROC (4Runner Owner's Club) > 4ROC > Florida
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-19-2008, 02:25 PM   #1 (permalink)
Abs Brakes
any one in the miami/ft lauderdale area with a 04runner that has the vstrack,tracoff,abs light on?what is the cure! i disconnected the negatoive term in the battery and refconnect. same problem, had a technician plug in an onboard meter and was told that the sensor is bad. is this possiaBLE. ANY ONE KNOW HOW MUCH THE SENSOR IS OR CAN YOU JUST REPLACE THE HARNESS OR THE SENSOR. ANY ANSWERE WOULD BE APPRECIATED FROM ANY ONE.
coconut is offline
Sponsored Links
To remove this ad, register today!
Old 10-02-2008, 04:30 PM   #2 (permalink)
4 runner ABS/TRAC/VSC lites
Mine come on when I get a little skid on a dirt road while braking. First time it happened, all those lights came on, and I did a search on this web site and a guy told me to unplug the ABS plug (on the brake master cylinder, along with about five other plugs) while the engine is running, turn off the engine, plug the ABS back in, and restart the engine. This should re arm the system. It took a a couple of times before I got it right. Can't remember which plug it is, but a car manual might show which one it is. Hope this helps.
condor is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Flushing Brakes - ABS? runner00 95.5-2004 Tacomas & 96-2002 4Runners 0 07-16-2008 03:44 PM
2000 Tacoma-bleeding ABS brakes? SEAIRESCUE 95.5-2004 Tacomas & 96-2002 4Runners 2 03-01-2008 09:17 AM
Is There a differance between front drive Shafts on ABS and Non-ABS equiped 4Runners? bc4r 95.5-2004 Tacomas & 96-2002 4Runners 5 02-01-2008 05:14 PM
Tundra Brakes & ABS - ??? ohio4runner4x4 95.5-2004 Tacomas & 96-2002 4Runners 2 09-10-2006 06:49 PM
ABS Light, Brakes Fine??? 4x4Lamm 86-95 Trucks & 4Runners 7 01-08-2006 06:31 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
