Thoughts on the Honda Odyssey? What causes this problem? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Topic, Wiki Discussions, Fraudulent Vehicle Listings, & Stolen Rigs > Off Topic Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-30-2007, 10:40 AM   #1 (permalink)
DH6twinotter's Avatar
Hey all,
My sister and brother-in-law are looking at getting a 2002 Honda Odyssey. It's got 47,000 miles on it.
They are pretty serious about getting it, but they did have one concern with it. At about 75mph, the steering wheel vibrates a bit. I'm not really familiar with front end issues and I figured I'd ask you all's opinions on this. I know it is a bit vague, but any ideas what would cause a steering wheel vibration at 75mph? I had suggested maybe a thrown weight, bad tire, bad CV, or maybe wheel bearings, but I dunno. Any ideas?
It seems like a lot of these vans have had problems with the trannies going out. This particular van has had it replace once already.
Thanks all.
Daniel
__________________
1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto.
15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick
Planned stuff: Pre-runner light bar with Hella 500s, small lift
Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow.
DH6twinotter is offline
Old 04-30-2007, 10:45 AM   #2 (permalink)
navyredneck's Avatar
Don't know much about the vibration but every Honda I have ever driven has shifted roughly. Another reason why I've always driven the Honda and Toyota and then picked the Toyota
__________________
1985 pickup std cab 4wd rebuilt 2.4L 22r by Oregon Engine Rebuilders, RV cam, oversize valves, Weber 34 DGEC, 8k on engine,5 speed, OME shocks N93/N85 front/rear, rear diff breather, Durabak interior, Summit proportioning valve, SR5 cluster mod, 3" RB body lift, warn winch brushguard with harbor freight winch, custom rear bumper, FROR floating rear axle with pickup disc brakes all around
navyredneck is offline
Old 04-30-2007, 11:38 AM   #3 (permalink)
ewong's Avatar
could be a ton of things.
First things Id check are the visuals
-- tire wear - any cupping?
(Id suspect toe out - my Golf has this issue as we speak)
-- get it to an alignment shop that you trust
-- wheels bent or out of round
-- wheel balance
-- alignment
worn struts will have a "thrumming" at certain speeds (drive alongside and see if the wheel "bounces" at speed - ya gotta know what to look for tho)
BJ and Tie Rod ends?
then wheel bearings. and CVs...
When I get new cars its the first thing that gets rebuilt... (suspension)
ewong is offline
Old 04-30-2007, 03:47 PM   #4 (permalink)
More than likely the tires are out of balance.
Honda transmissions do shift a little different than others.
I have seen one odyssey between 01 and 03 go through two transmissions that were both put in by the dealer, but havent noticed a huge amount of problems with them. The worst thing you can do with them is rock them if you get stuck.
1994runner is offline
Old 04-30-2007, 04:06 PM   #5 (permalink)
coldwiz's Avatar
I bought our '01 Ody new in Dec '00 and it has been to the dealer only twice. One of those was the door lock on the back door was sticking and the other was an EGR valve recall. Needless to say it has been very reliable. The '02's had the 5 speed auto vs our 4 speed. That is when Honda started having a few problems with them. They seem to be taking care of the customers but I don't have any first hand experience.
The front end shake is probably a tire. It would be easy enough for your bro inlaw to take it to the tire shop and let them take a look. The dealer should be willing to spend $40 for this. Also check out:
http://www.odyclub.com
For more info.
__________________
2000 4Runner SR5 4WD V6 5SPD Diff Lock
coldwiz is offline
Old 04-30-2007, 04:12 PM   #6 (permalink)
91TPU's Avatar
Send a message via AIM to 91TPU
we had two odysseys i would assume a 98 and 02 and my parents loved both, only reason we didnt get another one is we needed AWD and a bigger vehicle so we bought a pilot...
as for the vibration, every honda i have ever owned, 3, needed to be aligned after about 30k of driving, also if the wheels are slightly out of balance, it shows at high speeds...
__________________
87' 4runner...22re...31" Bridgestone Dueler AT-New project rig and winter dd.
91' 3vze...190k...31" BFG All Terrain's...K&N FIPK-SOLD
07' Civic Si-The Daily Driver.
Quote:
Originally Posted by Sonofmayhem View Post
god hates you.
91TPU is offline
Old 04-30-2007, 04:18 PM   #7 (permalink)
xcmountain80's Avatar
I told my wife if she cam to me and said we needed a van we had 2 options. 1. We can buy a VW Eurovan VR6. 2 Or we can buy a E350 4WD.
Aaron
xcmountain80 is offline
Old 04-30-2007, 04:29 PM   #8 (permalink)
hmmwv15's Avatar
If they end up getting it and diagnosing the problem, check to see if it's a "lemon law" My uncle had a problem with his Odyssey, and looked up these "lemon laws" and ended up getting it fixed for free. Just a thought...
__________________
I haven't failed, I've just found several different ways NOT to fix this truck. :D
Sean
hmmwv15 is offline
Old 04-30-2007, 07:14 PM   #9 (permalink)
DealMaker's Avatar
if it isn't an alignment/wheel balance issue, then its probably a broken motor/transmission mount.
Our '99 Odyssey with 68K miles is on its 3rd transmission. Several broken motor mounts have been replaced. Both wiring harnesses (one for each power slider door) have been replaced. We're nearing the end of tire life on our second set of tires. The fuse box down by the E-brake isn't covered, and every so often when setting or releasing the e-brake a fuse is inadvertently knocked out by the drivers foot. Needless to say, the first time this happened caused a huge inconvenience to say the least. The thing has the worst, roughest ride and is so unbelievably loud. I swear I'll never buy another one. I get steamed when I consider that I paid a premium for this thing when it was new, with the rationalization that I was getting Japanese quality and a 2XX,000 mile vehicle.
The only reason why its still in my garage is because its paid for, and is unvelievably practical. Still, every thime I drive the thing, I swear that I'm going to trade it in for a new LC100.
__________________
'04 4Runner 4X4 SE V8
BFG KO 265/70/17 - Donahoe Coilovers - Deaver rear springs - Bilstein 7100 shocks - Hanna Sliders - Shrockworks Front Bullbar
DealMaker is offline
Old 04-30-2007, 07:18 PM   #10 (permalink)
what everyone else has staed is worth checking. we have an 03 Odyssey and we love it. The van is super safe and it real peppy with the V6.
Roadnoise is somewhat high but with kids screaming and yelling to doesn't make much difference for us.
You can't go wrong with the Odyssey. its a well built family hauler and is safe.
shantz is offline
Old 04-30-2007, 07:23 PM   #11 (permalink)
CJM
CJM's Avatar
Quote:
Aaron
I like you, I drive an E350 but it aint 4wd.. Such a pity, it's still a beast.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 04-30-2007, 08:30 PM   #12 (permalink)
I figure if it has to be a van make it a mans van!
Aaron
Old 04-30-2007, 08:49 PM   #13 (permalink)
nieuwendyk-25's Avatar
My brother-in-law has a 2001 or 2002 Accord that got a new transmission because of a recall. He also has a 2005 Odessey. THey love it but have had a few problems.
When my wife and I found out we were having triplets, she started talking mini-van. I put a stop to that real quickly by getting her a Sequoia....whew that was close!
It may not get the best gas milage, but that is the only thing we dislike about it. Plus I feel a lot safer with my family in a solid frame vehicle. If I absolutely had to get a minivan, the Honda would be my choice.
Anyway, sounds like alignment/balance to me.
__________________
DMN, D.D.S. "DOC"
2000 4Runner SR5 4WD- RADIANT RED, Toyota E-Locker, BFG AT's, Yakima Rocket Box, Toyota Ski Rack, Alpine Amp, iPhone interface, Focal 6.5" Components Front & REAR!, Monster Wiring, Husky Liners, Magellan Color GPS, Bilstein Sucks...I mean Shocks
2005 Sequoia SR5 4WD- BRILLIANT WHITE, Yakima RB, Husky Liners, 10.4" LCD/DVD Player, iPod interface, BFG AT's
1986 Jeep CJ-7- Hard & Soft Tops, Alpine CD, iPod interface, Polk Speakers, 31" BFG AT's, Bosch Lights, Mopar MPI
nieuwendyk-25 is offline
Old 05-04-2007, 04:51 PM   #14 (permalink)
Thanks for the help! I'll pass on the comments to my sis and bro-in-law. Really appreciate the comments. Huge help!
Daniel
__________________
Tags
box, odyclub, rocket, yakima
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Will this Odyssey battery will fit my '96? nick-m 95.5-2004 Tacomas & 96-2002 4Runners 3 11-16-2006 10:26 PM
Battery opinions?(Hawker Odyssey, Exide Orbital) r854rnr 95.5-2004 Tacomas & 96-2002 4Runners 13 10-29-2006 07:40 PM
Odyssey Off-Road Battery RTdawgs The Classifieds GraveYard 6 07-11-2006 08:27 AM
honda accord problem Ishinc Off Topic Talk 1 06-16-2005 12:27 PM
Recommend me a battery: Optima, odyssey, etc SLC Punk Off Topic Talk 26 11-07-2004 01:13 PM
2009 InternetBrands, Inc.
