PO171 System Lean Bank 1 Code for a 00 Toyota Corolla - YotaTech Forums
Go Back   >
Off Topic Talk If it's non Toyota & tech related, put it here
LinkBack Thread Tools Search this Thread
Old 07-11-2006, 11:58 AM   #1
Hello: I have my Engine Check Light On for a 2000 Toyota Corolla and I checked with an OBDII scanner and it gives the Code PO 171 Bank 1 System Too Lean. I cleaned the MAF Sensor as it was dirty as I have heard that this code can occur because of the MAF Sensor being dirty. But now when I cleared the Code by disconnecting the Battery, it still comes on. THe gas Mileage has not changed but there is a huge power problem when I start a Cold engine especially when the car is in the parking lot the whole day and its hot outside. Do you think my O2 sensors might be doing this? Please let me know.
amit007 is offline   Reply With Quote
Old 07-11-2006, 03:24 PM   #2
Elton's Avatar
did you disconnect the battery for 15mins?
Elton is offline   Reply With Quote
Old 07-11-2006, 03:51 PM   #3
MTL_4runner's Avatar
Quote:
It could be either a MAF or an O2 sensor (in front of the cat). Cleaning the MAF does not always work and sometimes it must be replaced to fix the problem. If the MAF is cheap for your car, I'd change it anyway. If that fails then you likely need to replace the O2 sensor.
MTL_4runner is offline   Reply With Quote
Old 11-04-2006, 01:27 PM   #4
PO171 Gone, Now its PO420
Thanks for all your help. I had PO171 sometime ago, changed the MAF sensor and the O2 sensor before the catalytic converter. Now I got the Engine Light on again and it says Code PO420. Please help!!!!! Do you think I will have to replace the whole catalytic converter. Any help is appreciated.
Old 11-04-2006, 01:51 PM   #5
Elton's Avatar
what o2 sensor did you use ?
Old 11-04-2006, 03:02 PM   #6
Quote:
Elton, I got a Densco O2 sensor installed. THe light did not go after that. Right after that I had a remanufactured MAF sensor installed and the light went out for about 2 months until it appeared back again.
Old 11-04-2006, 03:06 PM   #7
Elton's Avatar
code P0420 Catalyst System Efficiency Below Threshold wich is the o2 sensor you dont have more than one do you ..... also for fun clean the maf and see if that helps
Old 11-04-2006, 03:10 PM   #8
Elton: THanks for your prompt reply. I have an O2 sensor before and after a catalytic converter. THe dealer changed the one before the catalytic converter. Do you think the code is because of the sensor After the converter? I will certainly listen to you and clean the MAF sensor. Can this be because of an oil change which I am scheduled to do tomorrow? Your help is really appreciated
Old 11-04-2006, 04:14 PM   #9
Quote:
If you already had the O2 in front of the converter changed, then it would be wise to do the one after because the P0420 may be getting misreported by the rear O2 sensor. You might also see how much a new MAF is, if it isn't too much and replacing the rear O2 sensor doesn't fix it, you might want to replace the MAF. After you have done all of these and the P0420 code remains, I'm afraid you'll need to pony up for a new converter. Just do it in steps and replace one item at a time and resetting the ECU after each.
Erc code for car navi Himashi GPS & Communication 2 10-01-2015 08:29 PM
JMiller's 1981 2WD Pickup Jmiller1023 Pre 84 Trucks (Build-Up Section) 23 08-06-2015 08:03 PM
Idle dying/check engine light sonic concepts Newbie Tech Section 0 07-01-2015 03:33 PM
Code 25 problems 94hiluxZE 86-95 Trucks & 4Runners 0 06-22-2015 11:42 AM
New Toyota SUV's Hbum 95.5-2004 Tacomas & 96-2002 4Runners 20 07-23-2002 11:15 AM
Tags
171, 2000, 2001, 2003, bank, catalyst, code, corolla, efficiency, po, po171, scan, system, threshold, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
