New Trail Gear Product: rear Driveline Disconnect--I want - YotaTech Forums
Go Back   >
Off Topic Talk If it's non Toyota & tech related, put it here
LinkBack Thread Tools Search this Thread
Old 05-04-2011, 11:33 PM   #1
Fossilized
Staff
dropzone's Avatar
so not sure when this thing will be out, but I would like one
allows true front digs:
http://www.trail-gear.com/vbulletin/...ed=1#post51206
with the added length I wonder if the Front and rear Drive shaft length would be close enough that they would be interchangeable..it would be nice to carry one spare instead of two
being able to flat tow with out having to have a full floater with Hubs (like the FROR kit, though I still want that too) and having to pop the rear D/S would be nice.
dropzone is offline   Reply With Quote
Old 05-05-2011, 12:32 AM   #2
scuba's Avatar
Badass!
scuba is offline   Reply With Quote
Old 05-05-2011, 06:01 AM   #3
waskillywabbit's Avatar
Yep. Front digs are cool.
I bet it ain't cheap! It's also not allowed in the Ftoy class.
:wabbit2:
waskillywabbit is offline   Reply With Quote
Old 05-05-2011, 06:10 AM   #4
trdwssrs's Avatar
oOoOoo!
I likey! droool.
trdwssrs is offline   Reply With Quote
Old 05-05-2011, 06:14 AM   #5
xxxtreme22r's Avatar
Wahhhooo it's an air locker for your driveshaft.
xxxtreme22r is offline   Reply With Quote
Old 05-05-2011, 03:26 PM   #6
Zelephant's Avatar
Stupid, noobie question, but why would you want to make you rig FWD, even temporarily?
Zelephant is offline   Reply With Quote
Old 05-05-2011, 04:29 PM   #7
Google up "front dig"
Old 05-07-2011, 07:05 PM   #8
Fossilized
Staff
dropzone's Avatar
Quote:
also allows you to flat tow easier than dropping the rear driveshaft.
My flat bed trailer was unavailable so I used a tow dolley. it was raining and i was tired. didn't feel like pulling the rear d/s. one the way home truck slipped into gear, toasted my front T/C and transmission. very expensive lesson..
allow allows you to pull yourself around a tight obstacle using the front wheels...having the ability to just apply pressure to your rear brakes helps too...like cutting brakes. I had them on my old V-dub bug...made for some fun in the sand
Old 05-07-2011, 09:16 PM   #9
Zelephant's Avatar
Cool, thanks for the explanation. I did google "front dig," so I definitely understand it now.
More goodies for all-out builds and for the rest of us to drool over.
Old 05-07-2011, 10:34 PM   #10
James Woods's Avatar
Very cool, it also looks like a way better setup than the front range driveline disconnect.
James Woods is offline   Reply With Quote
Old 05-08-2011, 01:10 AM   #11
Fossilized
Staff
dropzone's Avatar
TG's won't need an extra hole through the floor^^
Old 05-30-2011, 09:42 PM   #12
muddpigg's Avatar
Will kinda suck for us short wheel base guys with dual cases.
But otherwise cool.
Could be usefull when winching out larger vehicles.
muddpigg is offline   Reply With Quote
Old 05-30-2011, 10:20 PM   #13
Fossilized
Staff
dropzone's Avatar
I am one of those short wheel base guys too...I wonder how close the measurements would be with this installed between front and rear driveshafts...if it got close enough it would be nice to only carry one spare D/S
Old 05-30-2011, 10:29 PM   #14
muddpigg's Avatar
Good point. I've been meaning to measure mine too.
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) 60 01-14-2017 05:16 PM
88 Pickup Transmission Swap mskalmus 86-95 Trucks & 4Runners 6 03-21-2016 12:41 PM
FS[PacSouthWest]: 2- 8"3rd members:4.88 ratchet lockers,new setup kit, rear axle rebuild kit,diff armor jerusry Axles - Suspensions - Tires - Wheels 1 10-19-2015 06:28 PM
4runner stalling in gear... Do this again please Jnkml 95.5-2004 Tacomas & 96-2002 4Runners 3 07-06-2015 02:20 PM
93 runner build MTLroadierunner 86-95 Trucks & 4Runners 0 07-06-2015 01:17 PM
Tags
dig, disconect, disconnect, drive, driveline, driveshaft, flat, front, gear, line, rear, shaft, tow, toyota, trail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
