Insulation along a concrete basement wall - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Topic, Wiki Discussions, Fraudulent Vehicle Listings, & Stolen Rigs > Off Topic Talk
Old 11-11-2007, 06:09 PM   #1 (permalink)
mehret's Avatar
Location: Williamsport (School,Work)/Palmerton (Home), PA
Send a message via AIM to mehret
Right now, we're in the process of finishing a room that we sectioned off in the basement, and we're at the point where we have to insulate the room. We used galvanized studs because there's a lot of moisture down there. One of the walls was framed along the foundation, and I'm not sure how to insulate it. I was told from a few people to put the foam board against the wall and then use regular fiberglass insulation.
I was wondering if anyone can tell me what they did and/or what is the proper way to insulate it.
__________________
87 Toyota Pickup 22r, 5pd., 220,000 miles, 15x8 steels, 31x10.5x15 BFG A/T, tiger camo
There are excuses and results: No one cares about the excuses.
mehret is offline
Old 11-12-2007, 07:31 PM   #2 (permalink)
Hoopster's Avatar
What's the cause of the moisture? Is it leakage or humidity? I would be leery about finishing a basement that wasn't completely dry. You're just asking for mold problems. A lot of times you can solve the moisture problem with a little knowledge about it's cause.
__________________
Remember the Constitution? Ron Paul does.
RonPaul2008.com ( Hope for America! )
But I was interested now to see something I had not noticed in 1984: in a long discussion on the flip side, "Why a BANKRUPT AMERICA?" there is a quotation from "Congressman Ron Paul." "I think it is high time that the American people found out exactly what the 'Fed' is up to in its domestic dealings, as well as in its relationship with foreign governments and international banks."
Hoopster is offline
Old 11-12-2007, 08:11 PM   #3 (permalink)
mehret's Avatar
Well, it's an old house. The foundation only really leaks when we have flood-like rain storms, and to alleviate the problem, we cut a channel into the floor for the water to go into, so the moisture isn't so much of a concern, I guess.
__________________
mehret is offline
Old 11-12-2007, 08:19 PM   #4 (permalink)
CJM
CJM's Avatar
I wouldnt dare finish the basement if I were in your shoes first without totally waterproofing and curing your water leakage issues.
I would use the reflective foam board over anything else, if it does get wet it wont turn to much like plain fiberglass or styrofoam.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 11-13-2007, 09:38 AM   #5 (permalink)
Hoopster's Avatar
It's hard to say without seeing it firsthand but I would start by making sure your gutters work perfectly and the downspouts have extensions on them to carry the water 5-6 feet away from the house. Then make sure the ground slopes away from the foundation all around, at least a few inches per foot. Is there a sump pump and if so, make sure it pumps away from the house also.
Doing all of this should cure 90% of basement leaks. Then concentrate on sealing cracks etc.
Is the foundation poured concrete or concrete block?
As said before I wouldn't do a thing to the basement until it's 100% dry!
__________________
Hoopster is offline
Old 11-13-2007, 05:18 PM   #6 (permalink)
breknraj's Avatar
Just going by your basic post, I would paint the concrete surfaces with a crack filling paint (dry-loc, I think). After that has had a chance to properly dry, then get some Tuff-R foil faced foam insulation boards - 3/4" would probably be a good choice. Cut and glue the pieces to the wall, accordingly (BTW, if you haven't already put the studs up along the concrete, do these tasks first! - then stud it).
Run your wiring and plumbing (if any), then fill the rest of the cavities with regular fiberglass insulation, or get it done in expanding foam, and then sheet rock and finish!
I have my half-daylight basement done this way, and it makes a HUGE difference in keeping it warm!
__________________
Raj : 1960 Homo Sapien. 192cm, Blonde, Blue. Soon to lose spare tire.
Worf : 1990 SR5 Xtracab 4x4 5 speed, Inca Red Metallic. 3.4 converted, with Taco 5 spoke alloys, 275/65R16 BFG AT K/Os. Soon to add rear e-locker.
breknraj is offline
Old 11-13-2007, 05:39 PM   #7 (permalink)
plumb bob's Avatar
Also good ventiation and heating will help keep it dry and warm.
It maybe worth install a sump pump, if it can flood, just to help limit damage when the heavy rain does come.
After all that hard work and money, you want it to stay dry for many years to come.
__________________
It's all about the money!
1989 Hilux Surf 2.4 TD (2LT) running on veg oil
Quote:
Originally Posted by fustercluck View Post
Hehe. We are a bad influence on the impressionable minds of the relucant!!!!!
plumb bob is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Owens Corning Basement Finishing System aka 1-800-BASEMENT TDiddy Off Topic Talk 10 11-28-2005 09:32 AM
When does concrete dry? Tacoma Dude Off Topic Talk 22 05-12-2005 06:44 AM
Concrete floor covering.Opinions??? FilthyRich Off Topic Talk 15 01-07-2005 02:44 PM
How do I remove concrete sealer? mangoango Off Topic Talk 1 09-08-2003 01:20 PM
How can I remove oil from concrete? jimrockford Off Topic Talk 6 05-22-2003 06:27 AM
2009 InternetBrands, Inc.
