| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
How does a 1991 isuzu trooper's 4wd work?
__________________
1985 4Runner 5spd 22RE on 30x9.50's I support MisterWillie. |
#2 (permalink) |
He wasn't able to back up to get his automatic hubs to engage. They work similar to the toyotas with early automatic hubs. It sucks if you get stuck before you engage 4wd, because then you can't reverse enough to get them to engage.
__________________
Chris 7th Annual Pismo Jamboree: Sept. 25-27, 2009 '93 4runner SR5 3.0 Auto 4WD '07 Tacoma Dcab 4x4 TRD offroad '89 F250 4x4 w/utility bed M416 1/4 ton military trailer "Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem." Ronald Reagan Semper Fi SLO 4wheelers |
#3 (permalink) |
My friend had a trooper... PITA to get in and out of 4 wheel drive. It would take 30 to 40 yards for it to kick in.
#4 (permalink) |
oh wow, that much huh?
__________________
#5 (permalink) |
Shouldn't they engage if you're spinning the tires? Or does it take both sides spinning to engage them?
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#6 (permalink) |
im wondering if the front tires have to be the ones going backwards for 30 yards
__________________
#7 (permalink) |
i think on his both sides had to turn in order for it to engage. The hard part most of the time was getting them back into 2wd. He would pull forward, backward, turn left, turn right and they would finally disengage
#8 (permalink) |
what a ridiculous system
__________________
#9 (permalink) |
It was good when it worked.... if it ever worked. Way to expensive to work on also
#10 (permalink) |
Any automatic hub configuration i have seen engages when you are in a forward gear. When you want to disengage the hubs, you back up 30 feet or so. the big disadvantage to this scheme is that the front hubs disengage if you are backing up in 4wd, so you dont have 4wd in reverse, only forward. most systems are shift on the fly, unless you are going into 4wd low.
__________________
85, 87 (SAS), 88 (on loan), 96 4Runners, all males... 03 Town and Country... female CLIK4PIX Last edited by misterzee; 01-04-2007 at 02:49 PM. |
#11 (permalink) |
both sides have to turn, plus if he is stuck in the snow in 2wd, he's not spinning either front wheel, just the rears.
__________________
#12 (permalink) |
True - I was thinking spinning the axles, not necessarily the wheels...
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1991 4runner 4WD question | roznov | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 12-30-2004 06:51 PM |
| Will a 1991 22RE head work on........ | AzStorm | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 10-15-2004 09:23 AM |
| How do balljoint spacers work (and do they work on 4wd)? | ianshoots | 95.5-2004 Tacomas & 96-2002 4Runners | 34 | 08-14-2004 03:07 AM |
| Interior Work 1991 | Travis | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 12-20-2002 01:18 PM |
