How do lock washers work? - YotaTech Forums
Go Back   >
Off Topic Talk If it's non Toyota & tech related, put it here
LinkBack Thread Tools Search this Thread
Old 08-26-2003, 11:52 AM   #1
TDiddy's Avatar
I'm on a hardware kick lately....
So here's another question I never bothered to ask anyone. How do lock washers work? What makes them lock?
For that matter, when should you use a wave washer?
I guess that's 3 questions.
TDiddy is offline   Reply With Quote
Old 08-26-2003, 12:10 PM   #2
AgRunner06's Avatar
Post Re: How do lock washers work?
When you tighten a lock washer it compresses. This compression puts an outward force on the nut. This outward force causes the threads on the nut and bolt to bind thus holding the nut in place. This is just what I think happens. I could be wrong.
And for the wave washer, I have no idea.
That's my stab at it.
AgRunner06 is offline   Reply With Quote
Old 08-26-2003, 02:05 PM   #3
mtnfreak's Avatar
What AgRunner just described was a 'wave' washer. Standard split lock washers follow the same principle, but add a 'biting' surface. When the nut tries to loosen, the edge on one side of the split bites into the nut; the edge on the other side of the split bites into the material below it. This keeps the nut from turning. Unless you can turn the bolt, the nut cannot be removed without damaging it or the other surface. Star lock washers have very little compression resistance. Instead they rely almost entirely on small tines which are alternately bent up and down. These tines bite into both the nut and the sub-surface, preventing the nut from turning.
mtnfreak is offline   Reply With Quote
Old 08-26-2003, 02:09 PM   #4
TDiddy's Avatar
Excellent, thanks!
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) 60 01-14-2017 05:16 PM
87 22r rebuild issue bigjstang 86-95 Trucks & 4Runners 14 12-09-2016 10:16 PM
Dash lights and interior lights wont work ashersullivan88yota 86-95 Trucks & 4Runners 12 07-28-2015 07:22 PM
Do I bother fixing it? 1993 3vz-E 4x4 Colington 86-95 Trucks & 4Runners 13 07-21-2015 06:24 PM
Aftermarket Rear View Camera Recommendations Suprarossa 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 0 07-06-2015 06:21 AM
Tags
laundry, location, lock, locking, lockwasher, lockwashers, machine, place, split, star, washer, washers, wiki, work, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
