Hot rod golf cart project - YotaTech Forums
Go Back   >
Off Topic Talk If it's non Toyota & tech related, put it here
LinkBack Thread Tools Search this Thread
Old 05-27-2004, 12:40 AM   #1
the_supernerd's Avatar
I have an old EZ GO utility vehicle in my backyard with a stripped rear end. I also have a 485cc Yamaha Phazer engine. I want to put the Phazer engine into the EZ GO utility vehicle, but there are a few issues that I need to figure out. The first is that I need a rear end. I have some spare golf cart rear ends with that same type of CVT clutch on them, but I think that they probably would not be able to handle the power of the snowmobile engine. The other issue is that I would like it to have reverse. I had a few ideas, such as using a rear end and transmission from a pickup or Suzuki Samurai and adapting the shaft on the transmission so I could fit the driven end of the CVT on it. This seems a bit too complicated and there is probably not enough room. I am wondering if anyone here has any ideas to get this thing working with a strong enough rear end and reverse, and possibly some parts for sale in the northern California area.
the_supernerd is offline   Reply With Quote
Old 05-27-2004, 06:14 AM   #2
PirateFins's Avatar
What about a rear end from a 4 wheeler ATV? I would think you could find one that is made for that size motor and will have reverse.
PirateFins is offline   Reply With Quote
Old 05-27-2004, 08:34 AM   #3
I don't think a 4Wheeler rear end would work, I used to race quads and inorder for it to work you would have to rig up a way to put the swingarm in with it also because the swingarm holds your axle bearings.
And I don't thing a little swingarm would hold up on a golf cart thing.
Plus if you were to be taking it off road you wouldn't have any articulation with a 4wheeler rear end.
mxracer0486 is offline   Reply With Quote
Old 05-27-2004, 12:07 PM   #4
I thought about using a 4 wheeler rear end, but the main problem there is that it is too small. I was also thinking that a rear end from a 4 stroke golf cart, such as a Club Car, that has reverse in the rear end. The only issue there is the strength. Thanks for the ideas. Does anyone know if a rear end exists with reverse built in? Kind of like a 2 speed rear end in a big rig or dump truck, only reverse is one of the gears and one that is a lot smaller.
Old 05-27-2004, 12:33 PM   #5
3.4v6's Avatar
this was at the truckfest here in norcal.
http://community.webshots.com/photo/...46891685wilxLw
3.4v6 is offline   Reply With Quote
Old 12-28-2007, 04:11 PM   #6
88-surf's Avatar
update?
88-surf is offline   Reply With Quote
Old 12-28-2007, 06:54 PM   #7
It has been a while since I had that project. I ended up getting rid of it because I could not get the engine to fit. I tried lifting the rear of the cart to make more room, but things were just not working. I also was tried putting it in another cart that I had which had enough room, but the rear end in that one was stripped and I could not find another one anywhere. The only place I could find a rear end was at a golf cart dealer and he wanted over $1000 for it, so I ended up scrapping all of them and selling the engine.
3.4L swap, overheating, burp darn you. LotOMiles 95.5-2004 Tacomas & 96-2002 4Runners 8 09-15-2015 12:45 AM
Upper control arm bushing lifespan aowRS 95.5-2004 Tacomas & 96-2002 4Runners 4 09-12-2015 01:41 AM
94 pickup (22re) slow warm up after rebuild --Oz-- 86-95 Trucks & 4Runners 1 09-06-2015 02:06 AM
Nitro Gear Project "Murph" 97 FZJ80 justdifferentials Vendors Build-Ups (Build-Up Section) 0 09-05-2015 07:52 PM
94 3.0l Cold Idle???? moparbay 86-95 Trucks & 4Runners 1 09-03-2015 01:48 PM
Tags
29, arm, axle, axles, cart, clutch, driven, end, ends, engine, ez, fit, golf, kart, rear, swing, transmission, wheeler
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
