Gas in the Oil? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Topic, Wiki Discussions, Fraudulent Vehicle Listings, & Stolen Rigs > Off Topic Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-27-2007, 08:03 PM   #1 (permalink)
nieuwendyk-25's Avatar
Gas in the Oil?
Other than a bad float, what can cause gas to get in the engine oil?
And is it possible for an engine that has no float problems (MPI) and that runs smoothly with plenty of power to get gas in the oil?
If there was gas in the oil how would you know it? Smell? Separation upon drainage?
I am suspicious of there being gas in the oil of one of my Vehicles...only from the smell of the oil once it has been in the engine...it is not an overbearing gas smell...and my nose may be off a bit...but I am trying to figure out how it could have gotten there (if it is there at all).
__________________
DMN, D.D.S. "DOC"
2000 4Runner SR5 4WD- RADIANT RED, Toyota E-Locker, BFG AT's, Yakima Rocket Box, Toyota Ski Rack, Alpine Amp, iPhone interface, Focal 6.5" Components Front & REAR!, Monster Wiring, Husky Liners, Magellan Color GPS, Bilstein Sucks...I mean Shocks
2005 Sequoia SR5 4WD- BRILLIANT WHITE, Yakima RB, Husky Liners, 10.4" LCD/DVD Player, iPod interface, BFG AT's
1986 Jeep CJ-7- Hard & Soft Tops, Alpine CD, iPod interface, Polk Speakers, 31" BFG AT's, Bosch Lights, Mopar MPI
nieuwendyk-25 is offline
Old 10-27-2007, 08:05 PM   #2 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
if its enough you could smell it. i flooded my engine pretty bad and i drained the oil and it smelled badly of gas.
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 10-27-2007, 08:06 PM   #3 (permalink)
btw i pulled the dipstick and could smell the gas on it through the oil
__________________
Old 10-27-2007, 09:48 PM   #4 (permalink)
Quote:
I thought I was smelling it, but know I am beginning to think I am imagining it.
I had a bad carb on my Jeep and it failed emissions...it now has the MPI (fuel injection) kit on it, and should not be flooding. I thought it smelled like gas before, and now I have changed the oil twice and I think it is in my head! Guess I will find out at the emissions test, eh.
__________________
DMN, D.D.S. "DOC"
Old 10-28-2007, 07:00 PM   #5 (permalink)
Anyone???
__________________
DMN, D.D.S. "DOC"
Old 10-28-2007, 09:14 PM   #6 (permalink)
MudHippy's Avatar
Quote:
PCV valve
From Wikipedia, the free encyclopedia
The Positive Crankcase Ventilation valve, or PCV valve, is a one-way valve that ensures continual evacuation of gases from inside a gasoline internal combustion engine's crankcase.
Explanation
As an engine runs, gases from the cylinders leak past the piston's sealing rings into the crankcase (containing the crankshaft and other parts). This leaked gas is sometimes referred to as "blow by" because the pressure within the cylinders "blows" them "by" the piston rings. These gases include compounds harmful to an engine, particularly hydrocarbons (unburned fuel), as well as carbon dioxide and water vapor. If allowed to remain in the crankcase, or become too concentrated, the harmful compounds will condense out of the air within the crankcase and form corrosive acids and sludge on the engine's interior surfaces. This can harm the engine as it tends to clog small inner passages, causing overheating, poor lubrication, and high emissions levels. To keep the crankcase air as clean as possible, some sort of ventilation system must be present.
Clogged PCV system, or leaky rings?
Sounds possible you could be accumulating blow by in your oil, either from lack of ventilation or worn piston rings. You should check your compression to make sure it ain't your rings. Unless you suspect it's a PCV issue. Still wouldn't hurt to check it anyway if you can.
__________________
Sonoran Steel Early IFS Truss
Your IFS is SPINELESS without it
SonoranSteel.com
I'm Cuckoo For YOTA Trucks!
MudHippy is offline
Old 10-28-2007, 09:33 PM   #7 (permalink)
Thanks for the good info:
That is one of the things I had figured might cause gas in the oil, but wouldn't the engine suffer from power loss or run poorly if there was a loss of compression? That is what is puzzling...it runs great and has lots of power.
The PCV system is brand new since the MPI kit replaces all of its components. However it could still have a little residual from the old system.
I am going to take it for the emissions test as soon as I replace the tailpipe...if it fails, or has a high hydrocarbon reading I will test the compression next.
__________________
DMN, D.D.S. "DOC"
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
gas in oil bowtiebinder 86-95 Trucks & 4Runners 5 08-22-2006 11:56 AM
Oil & Gas celica Off Topic Talk 7 04-13-2006 02:57 PM
Why does my oil smell like gas?? epic37311 95.5-2004 Tacomas & 96-2002 4Runners 13 01-06-2005 03:06 AM
gas vs. oil charged shocks ??? humanoid 95.5-2004 Tacomas & 96-2002 4Runners 2 12-18-2003 07:04 PM
2009 InternetBrands, Inc.
