Diesel Turbo Information - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Topic, Wiki Discussions, Fraudulent Vehicle Listings, & Stolen Rigs > Off Topic Talk
Sign in using an external account
Register Forgot Password?
Off Topic Talk If it's non Toyota & tech related, put it here
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 07-24-2005, 07:46 PM   #1 (permalink)
Personal Sales Rating: (0)
rngrchad's Avatar
Anyone who is familiar with diesels chime in.
What kind of power or boost lag difference is there between twin turbo's and single turbos? Is there more useable power between one or the other. I would think twin's would lag waaayyy more than a single turbo meaning slower off the line but pull further in the revs because of more boost? Anyway I'm just curious, my friend is looking into twins and I can't figure out why.
I've looked online and can't come up with hardly any info. I'll probably have to stop at the local diesel shop and go bug the techs.
thanks
__________________
2008 Tacoma TRD Access Cab v-6. 97 regular cab tacoma 33x9.5bfg at, 4.10 gears, custom sliders, custom rear bumper, 4xinnovation tube doors, lockright. 1983 SA Axle Frameoff Restore. CB: Connex 3300hp Radio driving a FatBoy Amp doing around 1000watts on AM. Antenna: Monkey Made MM5
-=NO BAMA 08 =-
rngrchad is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 07-24-2005, 08:01 PM   #2 (permalink)
joez's Avatar
Send a message via AIM to joez
Twins spool up faster, signifignatly faster if he is burning enough fuel for them. Depending on the setup, they will also tow nicer with more boost where you need it. Not to mention the potential to make a lot more power. It will help lower EGT's as well by getting more air in quicker, before they have a chance to climb. I assume he is considering them for the Cummins, check out TDR and you will learn alot.
__________________
-Joe Z
Chicago 4x4
My Webshots
1985 Toyota 4Runner, 3" Trail Gear rear/ All-Pro front springs, 42x14 IROK's, Allied Rockathons, spool rear/detroit front, 30 spline longs, Dual cases w/4.7, Marlin High steer, lots of other stuff..
1997 Dodge 2500 4x4, 12valve CTD, not stock.
joez is offline
Old 07-24-2005, 08:09 PM   #3 (permalink)
Threadstarter [OP]
rngrchad's Avatar
Thanks for the headsup joez, I tried the turbo diesel registry however I thought I couldn't search the links because I do not subscribe to their magazine. hmmm I need to go back and re-check that site.
__________________
-=NO BAMA 08 =-
rngrchad is offline
Old 07-24-2005, 08:38 PM   #4 (permalink)
sequental twin turbos like the RX7 or the supra will spool up VERY fast because one turbo is small that spins up fast and that accualy gets bypassed for the bigger turbo when it spins up.
You can have both turbos running at one time if the wasgate on the smaller turbo doesn't open which is GREAT for towing.
twin turbo setups are great but can't yeild as much power as a single MASSIVE turbo.
many of the drag racer's with supras opt for a single turbo conversion to run more boost
__________________
Crouch Rocket 2005 Felt F80 Mavic Kiriums, Speedplay Zeros.
2006 Mazda3 GT
2000 TRD Tacoma..Bought back and crushed
1988 4Runner SR5 V6 5 speed..sold
89macrunner is offline
Old 07-26-2005, 07:44 AM   #5 (permalink)
joez's Avatar
Not true. While on gassers this is how it is, most of the high power diesel guys are running way more boost than 99.9% of gassers could even dream of. Richard (maddog, the one video that has been circling the internet for a year or so now with him smoking an RX7)) was running right arround 100 psi of boost with twins to get his lifted, cummins powered crew cab ford into the low 11's, and there are many other people pushing boost numbers up there as well. Singles are only good for about 30-45 psi reliably for daily driving/towing, and even that has noticeable lag and higher EGT's than a Twin setup pushing the same boost. There are people who push their singles higher, but usually they are battling EGT's that constantly want to push over 1300 degrees with the blink of an eye.
__________________
-Joe Z
Chicago 4x4
My Webshots
joez is offline
Old 07-26-2005, 01:28 PM   #6 (permalink)
Quote:
yes on gassers it is true...disels push out loads more exhaust and can run more MUCH more boost than a gsoline engine for one important reason
no spark plugs!
__________________
2006 Mazda3 GT
Old 07-26-2005, 09:20 PM   #7 (permalink)
kyle_22r's Avatar
yep, air is free when you have a diesel, no such thing as preignition!
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Yotatech
4WD Truck
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
2.4 Turbo Diesel Problem Plz Help coupehq 86-95 Trucks & 4Runners 24 07-09-2007 07:11 AM
Diesel 3.0 TD engine, information Igor YU 95.5-2004 Tacomas & 96-2002 4Runners 1 10-04-2006 06:11 AM
Turbo Diesel in a 4Runner? DeckerT4R 95.5-2004 Tacomas & 96-2002 4Runners 18 09-30-2006 10:00 AM
3.0L turbo diesel swap 4chucker 86-95 Trucks & 4Runners 1 12-14-2005 03:45 AM
3.0 turbo diesel? Babypig 95.5-2004 Tacomas & 96-2002 4Runners 2 07-18-2003 10:35 AM
Contact Us - YotaTech - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
2010 InternetBrands, Inc.
