chevy avalanche rear brakes - YotaTech Forums
Go Back   >
Off Topic Talk If it's non Toyota & tech related, put it here
LinkBack Thread Tools Search this Thread
Old 07-06-2006, 10:47 AM   #1
Buck01's Avatar
Anyone know how to get the rear brakes off a chevy avalanche?
more precisely the drivers side rear....the passengers came right off.
Buck01 is offline   Reply With Quote
Old 07-06-2006, 11:01 AM   #2
getitdone's Avatar
A Bfh.
getitdone is offline   Reply With Quote
Old 07-06-2006, 11:03 AM   #3
snap-on's Avatar
adjust the shoes in so they dont catch the lip of the drum....
we are talking drums/shoes right?
snap-on is offline   Reply With Quote
Old 07-06-2006, 11:03 AM   #4
Buck01's Avatar
lol that's what I thought. There is a dust sheild on the inside of the rotor so you cant hit it that direction. Gonna try smacking it the other direction and see if it will move at all.
Old 07-06-2006, 11:03 AM   #5
Buck01's Avatar
they are front and rear disks...with a parking brake
Old 07-06-2006, 11:18 AM   #6
getitdone's Avatar
smack the drum part towards the truck. Not away like your thinking. Trust me, it will nock it loose enough to pull off.
Sometimes you gotta hit it REALLY hard. Don't be scared to wail on it.
Old 07-06-2006, 11:18 AM   #7
Buck01's Avatar
thats my plan for right now. but it is a rotor not a drum.....
Old 07-06-2006, 07:20 PM   #8
Sponsoring Member
fustercluck's Avatar
I use a strategically place brass drift and beat the stink out of it 'til it breaks loose.
fustercluck is offline   Reply With Quote
Old 07-06-2006, 07:24 PM   #9
Cebby's Avatar
Are the e-brake shoes the type that push on the inside of the rotor "hat"? That's how my JGC ones are. Maybe release the e-brake? Sometimes it is something simple...
Cebby is offline   Reply With Quote
Old 07-06-2006, 08:20 PM   #10
Being a former Chevy dealer tech I will give the definitive answer to this. Hit the center part of the rotor near the hub(of which the center part is actually a drum for your e-brake) with a big hammer pretty much all over. Whack it from back to front of the vehicle, front to back, and in towards the truck. Eventually it will come off. You do risk warping the rotor in this case, although there isn't much you can do about it. Check your e-brake shoes and the drum surface closely because there's usually a reason they stick. Those e-brakes are notorious for burning up when left on.
WillsFJC is offline   Reply With Quote
Old 07-06-2006, 08:24 PM   #11
Quote:
wow, I didnt know it took so little to warp rotors. I dont tihnk changing brake pads are vehicle specific...LOL
I use a rubber hammer and just hit the outermost part of the rotor, it will eventually come off.
Localmotion is offline   Reply With Quote
Old 07-06-2006, 08:42 PM   #12
I wasn't trying to be an ass with that definitive answer part, I've just encountered several of those things, and no amount of rubber hammer will take the worst of those off. I remember one that came in where a lady had left her e-brake on long enough to burn up the e-brake shoes, brake pads, and managed to weld the metal shoe to the drum portion of the rotor. There's a reason the brake light flashes if you leave your e-brake on on those things.
Old 07-06-2006, 08:50 PM   #13
sorry man, I wasnt implying that you were an ass. My bad. I figure this is just a normal BJ(brake job you sick0s!) yea, there are lots of idiots out there
Old 07-06-2006, 09:18 PM   #14
Sponsoring Member
Quote:
So is there a correlation between toothless technicians and great "BJ's"?
Old 07-06-2006, 11:03 PM   #15
I knocked my front teeth out doing rear brakes on a van once...
Now as far as those other types of bjs, I leave them to the girlfriend.
Old 07-07-2006, 04:59 AM   #16
Buck01's Avatar
Thanks guys...I beat the heck out of that rotor last night with a 3lb sledge...still not off....the ebrake is not set..but we went ahead and disconnected the cable also just in case....
it is definetly the ebrake that has got it by the short hairs but I cant get this thing off so far....
I want to bust the dust sheild off the back side and beat the rotor from that side...my brother doesnt want to do that...YET...
Old 07-07-2006, 08:18 AM   #17
Keep beating, you may have to hit the surface of the rotor but you should not have to mollest the backing plate in my experience. Either way those things are a mother f'er, good luck.
Old 07-07-2006, 10:01 AM   #18
getitdone's Avatar
I wouldn't hit the surface of the rotor. Only hit the drum part(IE ebrake part). I would get a bigger hammer or look on the drum part for two threaded holes. Usually they have these threaded holes to screw in two bolts. The bolts push against a part on the other side which in turn pops the rotor off. Hopefully your rotor has em.
Good luck and get the damn things off!
Old 07-07-2006, 10:06 AM   #19
The Chevy rotors in question do not have bolt holes. If it really is as frozen on as it sounds he probably will have to beat the rotor surface as well and buy a new one, obviously this should be a last resort.
Old 07-07-2006, 07:55 PM   #20
Sponsoring Member
What if you heat the rotors at the lugs with a torch? Maybe the expansion caused by heat would help break it loose.....
Flying91's 1991 4runner LOWEST SAS 30" tires Flying91 86-95 Trucks & 4Runners (Build-Up Section) 31 01-14-2017 09:27 PM
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) 60 01-14-2017 05:16 PM
Rear end for an 89 pickup rondogracing Solid Axle Swaps, All Years 0 07-14-2015 08:00 PM
Rear brake line routing 87turboPA 86-95 Trucks & 4Runners 0 07-09-2015 06:58 AM
speedometer 'freaking out' wilbertd 86-95 Trucks & 4Runners 2 07-06-2015 08:39 AM
Tags
2004, 2005, avalanche, backing, brake, brakes, change, changing, chevy, front, job, pads, plate, reaqr, rear, shoes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
