YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-10-2008, 11:01 AM   #1 (permalink)
help with engine light
Hello,
I have a 1989 Toyota Pick up with a recently replaced engine, after driving for about 6 months the check engine light came on. I have taken it to my mechanic and the toyota mechanic and they cannot figure it out. the codes read 25 and 26. We replaced the oxygen sensors with no luck of fixing the problem. the toyota guys say it is running rich and lean--but this shouldn't be possible. the truck runs fine, althrough I have to adjust the throttle every now and then. how can I fix the check engine light, what is wrong?
riversair is offline
Sponsored Links
To remove this ad, register today!
Old 10-13-2008, 08:17 PM   #2 (permalink)
89needsatranny's Avatar
i have the same problem....... i have an 89 also(3vze)
__________________
white '89 3vze Pickup
<3 BC
89needsatranny is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
vsc trac light on with check engine light j4eric 03+ 4Runner/GX470, & 05+ Tacomas 2 08-26-2008 10:12 AM
check engine light and engine studder? pig 86-95 Trucks & 4Runners 15 12-10-2007 06:32 PM
Power Light/ Engine Light /Alternator Light 4runnerluver 86-95 Trucks & 4Runners 7 11-29-2007 04:57 AM
Engine Miss/Check engine light - Possibly TPS? Extremesolo 95.5-2004 Tacomas & 96-2002 4Runners 2 09-17-2005 09:58 PM
check engine light + engine miss descendents 95.5-2004 Tacomas & 96-2002 4Runners 6 11-03-2003 07:51 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
