YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Marketplace > Members Classifieds > Toyota Aftermarket & OEM Parts Suppliers > Vendor Advertising
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-30-2007, 10:28 AM   #1 (permalink)
traxman25's Avatar
Send a message via Yahoo to traxman25
Toyota Dual Transfer Case Cross Member and Mount
When 4x Innovations set out to design a new transfer case cross member we knew it wouldn?t be easy. After talking to may wheelers like you found out what mattered the most. Based on this we came up with this gem. Your new custom built cross member is designed to be low profile, but strong, and protective. This tube cross member is built from 1.5x.120 tubing to provide a great low profile fit, and durability and features 4 hard frame mounting points to help stiffen up your underbelly. These mounting points also allow it to stretch it?s reach and cover the bottom of the fragile cast aluminum transfer case and transmission housings that tend to crack if they meet face to face with a rock or hard place.
To help keep everything tucked up nice and neat under your rig we designed this cross member to use a new heavy duty transmission mounting bracket. This bracket replaces the stock mount with a new unit that houses poly round bushings to help eliminate play in your drive train. No more ripping stock mounts apart! By replacing the stock mount we were able to nest the tubes and the mount, meaning no valuable underbelly real-estate is wasted. As always, the new mount and all high grade hardware is included.
This cross member will fit your 84-95 Toyota pick up or 4 Runner that is or has had a Solid Axle swap. The stock torsion bars and torsion bar mounts must be removed. Don?t forget that 4x Innovations builds parts for YOUR truck, so customization for body lifts, 0-3 inches, is available FREE of charge! You can also order your cross member to be built for a 10 degree clocked transfer case, or a standard case.
Cost is $210 for the cross member, all mounting plates, hardware, and the HD transfer case mount, in either clocked or non clocked versions. To order you can use the online shopping cart here, or contact us.
For those of you who already have a cross member, but keep ripping your stock mounts; we have a solution for that too! Our stock replacement heavy duty transmission/transfer case mounts are now available!
toyota-dual-transfer-case-cross-member-mount-crossmemberx13l.jpg   toyota-dual-transfer-case-cross-member-mount-crossmemberx11l.jpg   toyota-dual-transfer-case-cross-member-mount-crossmemberx12l.jpg
__________________
4x Innovations - Quality Custom Toyota based tube products at a fair price
Toll Free @ 1-877-359-1611
Check out the 87 Runner trail rig.
-Adam-
traxman25 is offline
Sponsored Links
To remove this ad, register today!
Old 11-15-2007, 06:08 PM   #2 (permalink)
traxman25's Avatar
We have just lowered the price on these! They are now only $210, including EVERYTHING you need to mount your dual transfer case (minus the welder, welding accessories and the actual dual transfer case, and a truck itself, lol).
__________________
-Adam-
Old 12-14-2007, 07:41 AM   #3 (permalink)
traxman25's Avatar
bumper back to the top
__________________
-Adam-
Old 02-05-2008, 09:14 AM   #4 (permalink)
traxman25's Avatar
BTTT again.
__________________
-Adam-
Old 05-15-2008, 12:04 PM   #5 (permalink)
traxman25's Avatar
Don't forget to upgrade to the strongest cross member available when going duals this summer!
__________________
-Adam-
Old 09-26-2008, 01:22 PM   #6 (permalink)
traxman25's Avatar
back from the depths for those of you wanting a super strong t-case cross member!
__________________
-Adam-
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Transfer case gears and dual case Set up videos ocdropzone Offroad Tech 0 10-19-2007 10:29 PM
Dual Transfer Case Questions HaveBlue Offroad Tech 13 02-28-2007 04:52 AM
Dual Transfer Case Question Yotaboy Offroad Tech 7 06-01-2006 10:11 AM
dual transfer case, what will it do for automatic i_rifiyou Offroad Tech 14 12-12-2005 04:46 PM
2nd gen automatic dual transfer case option jay-q 86-95 Trucks & 4Runners 2 12-08-2005 02:08 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
