Super Duty Transfer Case Mounts - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Marketplace > Members Classifieds > Toyota Aftermarket & OEM Parts Suppliers > Vendor Advertising
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-08-2007, 05:22 PM   #1 (permalink)
traxman25's Avatar
Send a message via Yahoo to traxman25
As you have probably already discovered, off roading places heavy abuse on many parts of your truck that don?t get abused when your truck is driven ?normally?. One of such part is your stock transfer case mount. This soft rubber and steel block bolts between your transfer case and your transfer case cross member, and has a tendency to do one of two things when you are wheeling your truck. It will either flex far to much letting your shifter hit things in the cab, or even worse, the rubber will rip right in half! So now you?re in the middle of a trail, in the middle of nowhere, with a transmission/transfer case that is just flopping around, now what do you do?
To help you avoid such a situation, 4x Innovations has created the first true super duty transfer case mount for Toyota trucks! In this new mount the soft, weak, stock rubber portion of the mount is replaced with quality Energy Suspension Poly round bushings. These bushings will not split and fail on you, eliminating such worries associated with stock mounts. Your new mount comes with thicker steel plates that are laser cut and CNC formed for the best fit possible. This mount is a direct replacement and even includes all needed hardware. You can even run this mount with after market cross members that reuse the Toyota rubber mount.
As if all that wasn?t enough, there?s another trick feature to this mount. If you need remove your transfer case or transmission you now only need to remove two bolts from the bushings to pull the cross member down, not the 4, hard to get to, bolts that engage in the cross member.
Get the strongest mount available for your rig today for just $85. This mount fits all 79-95 Gear drive transfer cases and 82-95 4 cylinder cross members. To order please either contact us or click over to 4xInnovations.com and use the online shopping options.
__________________
4x Innovations - Quality Custom Toyota based tube products at a fair price
Phone @ 1-608-348-4880
Check out the 87 Runner trail rig.
-Adam-
traxman25 is offline
Old 11-13-2007, 09:28 PM   #2 (permalink)
traxman25's Avatar
Here's a picture of the real unit on the bench.
You may have some concern over these mounts introducing more vibration into the truck, but these are great bushings, and there is not actually much vibration at the mount. A customer brought this up when he was over this weekend, so we hoped in the shop truck for a drive. This 4 Runner is running the same style of mount/bushings (and has been for years), but it also has 2 inch round bushings for motor mounts. He felt it wasn't nearly as much as expected, and more than acceptable.
This unit bolts right up, just like a stock one would. And it bolts in ALL of the places you would use this shaped OEM unit!
super-duty-transfer-case-mounts-transmount1s.jpg   super-duty-transfer-case-mounts-transmount2s.jpg   super-duty-transfer-case-mounts-transmount4s.jpg
__________________
-Adam-
Old 11-15-2007, 11:06 PM   #3 (permalink)
traxman25's Avatar
More pics
super-duty-transfer-case-mounts-transmount6s.jpg   super-duty-transfer-case-mounts-transmount7s.jpg
__________________
-Adam-
Old 12-12-2007, 07:43 PM   #4 (permalink)
traxman25's Avatar
back to the top.
__________________
-Adam-
Old 01-17-2008, 10:48 AM   #5 (permalink)
traxman25's Avatar
back to the top again.
__________________
-Adam-
Old 02-06-2008, 03:56 PM   #6 (permalink)
traxman25's Avatar
Bump for the best stock replacement transfer case mount available!
__________________
-Adam-
Old 04-03-2008, 01:54 PM   #7 (permalink)
traxman25's Avatar
ttt again
__________________
-Adam-
Old 05-12-2008, 02:16 PM   #8 (permalink)
traxman25's Avatar
Here's a picture of the mount now zinc plated with black die. Don't forget to get yours ordered before this batch sells out!
__________________
-Adam-
Old 09-19-2008, 08:11 AM   #9 (permalink)
traxman25's Avatar
We have these in stock and ready to ship!
__________________
-Adam-
Old 10-17-2008, 02:06 PM   #10 (permalink)
traxman25's Avatar
I have these in stock and ready to ship! I even ship them international with USPS. Order yours today!
__________________
-Adam-
Old 12-21-2008, 09:26 AM   #11 (permalink)
traxman25's Avatar
In stock and ready to go! Anyone from YotaTech running these? Post up how you like it.
__________________
-Adam-
Old 02-27-2009, 06:54 PM   #12 (permalink)
traxman25's Avatar
back to the top, thanks!
__________________
-Adam-
Old 02-27-2009, 07:48 PM   #13 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
I do need to get me some of these for the 85 ext cab project.
waskillywabbit is offline
Old 05-13-2009, 11:54 AM   #14 (permalink)
traxman25's Avatar
These are on special for the month of May. Get yours while the deal lasts!! In stock and ready to ship.
__________________
-Adam-
Old 05-13-2009, 12:21 PM   #15 (permalink)
neoworm0's Avatar
Send a message via MSN to neoworm0
I am running this on an SAS'd dual case PU with a 3.4l and there is very little noticeable vibration. Great Mount!
__________________
1995 Toyota PU SR5. 2000 3.4l V6 and a few other mods.
my album:
http://www.yotatech.com/album.php?albumid=101
my SAS:
http://picasaweb.google.com/areinhol...eat=directlink
www.overlandcanada.ca
www.alltracwagon.net
neoworm0 is offline
Old 06-01-2009, 11:05 AM   #16 (permalink)
traxman25's Avatar
Quote:
Thanks for the feed back!!
These are in stock and ready to ship.
__________________
-Adam-
Old 06-22-2009, 11:39 AM   #17 (permalink)
traxman25's Avatar
These are in stock and ready to ship!
__________________
-Adam-
Old 08-11-2009, 08:41 AM   #18 (permalink)
traxman25's Avatar
These are in stock and ready to ship! Don't forget for to add engine mounts also for the ultimate in drive line mounting.
__________________
-Adam-
Old 08-31-2009, 06:18 PM   #19 (permalink)
I bought the transmission mount and 2motor mounts for my '84 4x4Pickup from 4xinnovations. The mounts are very rugged and design is great.
Only one complaint: no instructions are included!
I unknowingly installed one part upsidedown and spent 4 afternoons after work fighting with it because of that.
All-in-all I'm happy and the mounts are rock solid.
CarbedNotch is offline
Old 08-31-2009, 09:15 PM   #20 (permalink)
my truck
Thank you 4X and Adam, you fixed my engine slop for good!
Old 11-06-2009, 08:31 AM   #21 (permalink)
traxman25's Avatar
These mounts are in stock and ready to ship!
__________________
-Adam-
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Dual case crossmember with x-fer mounts lizard lips The Classifieds GraveYard 2 10-24-2007 11:59 AM
Transfer case gears and dual case Set up videos ocdropzone Offroad Tech 0 10-19-2007 10:29 PM
WTB: 4cyl Transfer Case mounts UKMyers The Classifieds GraveYard 1 03-08-2007 09:33 AM
super duty spy shots fiveofeen Off Topic Talk 21 08-30-2006 03:01 PM
Toyota FTX Super-Duty Concept BT17R Off Topic Talk 22 01-09-2004 04:58 PM
2009 InternetBrands, Inc.
