YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Marketplace > Members Classifieds > Toyota Aftermarket & OEM Parts Suppliers > Vendor Advertising
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-14-2008, 11:09 AM   #1 (permalink)
ORS
ORS's Avatar
ORS SALE - Toyota Rear Long Travel Shock Mounts
One factor working against long travel in the rear suspension is the original shock mounts. With the shock absorbers in the original location, the leaf springs strike the shock bodies, causing damage and limiting travel. The mounts are also too close together to accommodate a long travel shock. The ORS rear long travel shock mount set solves this problem by moving the shocks away from the springs and placing the mounting points further apart. This weld-in kit includes the upper hoop, lower mounts, gusset plates, and all necessary hardware. This kit allows the use of 12-14" travel shock absorbers, depending on ride height and application.
$137.00
Available for:
1995.5-'04 Tacoma
1999-'05 Tundra
1984-'89 4Runner, 1979-'95 4WD Pickup - No B/L
1984-'89 4Runner - 2" B/L
Order Online
__________________
Off Road Solutions
Arvada, CO
303-278-6267
www.offroadsolutions.com
Offering offroad products, engine conversions & custom fab work for your Toyota (& much more...)
ORS is offline
Sponsored Links
To remove this ad, register today!
Old 04-23-2008, 09:25 AM   #2 (permalink)
ORS
ORS's Avatar
Here are some better pictures of the kit installed.
We just installed this on a Tundra yesterday.
Here is the top bar with the shocks mounted
Here is the top bar welded to the frame
Here are a ton of pictures of the bottom (axle) shock mounts welded on
Underneath the bottom axle mount
overtop the bottom axle mount
__________________
Off Road Solutions
Arvada, CO
303-278-6267
ORS is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Long travel shock mounts Rocklobster The Fab Shop 1 06-23-2005 04:51 PM
Long travel Rear shock set up oly884 Offroad Tech 9 07-31-2003 11:29 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
