YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Marketplace > Members Classifieds > Toyota Aftermarket & OEM Parts Suppliers > Vendor Advertising
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-08-2008, 10:12 AM   #1 (permalink)
Chris_Geiger's Avatar
New Product, Trail-Link Four, Rear Suspension Kit
Press Release 5/08/08
Trail-Gear Inc now has an easy to install rear 4-link kit for 1979-1995 Toyota Pickups and 4Runners. The kit features a heavy duty frame crossmember that serves as a mounting point for all four links. Weld on axle link brackets are provided for either Toyota or Trail-Gear Rock Assault ™ style axle housings. Links are made from 2” X .250 wall DOM. Weld in threaded bungs, jam nuts and heavy duty, 1.25 link joints complete each of the four links. Wheelbase can be adjusted at the time of assembly by mounting the crossmember forward or backward. This suspension allows for full travel with up to 18” shocks. Can be used with or without stock rear frame section.
Kit Includes:
(4) 2" X .250" wall DOM links
(8) 1.25" Johnny Joints (4 right, 4 left)
(8) Rod end jam nuts
(8) Threaded link end bungs
(1) Frame crossmember
(2) Frame Gussets
(1) Axle housing upper mount
(2) 20 Degree axle housing lower mounts (left and right)
(2) Shock mounts with bolts, and bushings
(8) 9/16" X 4" link end bolts and lock nuts
Kit cost is $949. Kit does not include shocks, or upper shock mounts.
http://www.trail-gear.com/trail-link-4.html
__________________
www.Trail-Gear.com
Chris_Geiger is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Trail Link Suspension Justinvd 84-85 Trucks & 4Runners 2 04-12-2008 01:39 PM
4 or 5 link rear suspension kit for 94 2wd prerunner project subliminaltrips 86-95 Trucks & 4Runners 8 03-07-2006 04:40 PM
Rear 3 link kit on the market!! 85runner The Fab Shop 21 12-30-2003 08:11 PM
4 Link rear suspension...weld on or bolt on? Los Gatos? 95.5-2004 Tacomas & 96-2002 4Runners 1 06-21-2003 06:20 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
