would any of you post a write-up on how to install the sonoran steel truss?
Old 08-06-2007, 03:39 PM
TC4RNR's Avatar
i'm gonna do mine this weekend, any tips and tricks are welcome
thanks
Old 08-08-2007, 11:09 AM
nmtoy's Avatar
Quick recap of how I did mine:
Put the truss in place and hold it there with a floorjack
Use a centerpunch to mark the center of each of the 4 holes on your frame.
Carefully drill the backside holes starting with a 1/4" drill bit, go slowly and use cutting fluid on the drill bit.
Enlarge the holes to 3/8" making sure to keep your drill level and straight.
Drill through the front of the frame and the truss from the backside (my 3/8" bit was long enough) making sure to keep your drill level and straight.
Make sure the bolts fit through both sides of all 4 holes.
Paint and do the final install.
Hope this helps!
Robb
Old 08-08-2007, 12:23 PM
TC4RNR's Avatar
i went through steve's original post regarding the IFS Truss.
https://www.yotatech.com/forums/f37/...el-name-73531/
there are pre-drilled bolt hole ONLY on the back side, no holes on the from side. from the picture he posted,
i have to drill through the horns back and front then the front side of the truss, right?
i believe steve did it the truss the way it is with a reason, my question is why the front side doesn't have pre-drilled holes?
Old 08-08-2007, 12:40 PM
Guest
seanz0rz's Avatar
probably because its impossible to get it truely straight shot through. so while you drill through one side, the other side might not match the predrilled holes in the truss. plus, the angle of the hole through the steel may cause problems putting a bolt through.
now i know you could drill the rear hole, then drill the front, and they would match ok, but i think it is easier to drill through the whole thing in one straight shot, that way you know your bolt will go through.
just a thought.
Old 08-08-2007, 12:58 PM
nmtoy's Avatar
There is no room to drill from the front. It's really easy to do all the drilling from the backside.
Old 08-11-2007, 12:31 PM
TC4RNR's Avatar
take a look at the problem i ran into this morning when i tried to install the truss.
the driver side got in with no problem, but on the passenger side, the front right corner of the halfpipe got blocked by the front differential housing, pictures are following:
i marked the bolt hole, as you can see, there isn't much of meat for the bolt to grab.
i can trim down the corner with a cutting wheel, but from what i'm see now, i have to cut off a lot of steel. i'd prefer to ask around before i do some thing stupid and irreversible.
Old 08-13-2007, 06:28 AM
sschaefer3's Avatar
There is something off with your truck, that front diff is over more. You will have to grind the corner of the truss down, it will be fine, there is alot of metal there.
Old 08-13-2007, 02:43 PM
TC4RNR's Avatar
wooohooo!! just another reason to play with a cutting wheel.
school me on the front differential, is it firmly mounted on the frame or it has some flex, i mean how much clearence i need to leave between the truss and diff. housing.
thanks
Old 08-13-2007, 02:47 PM
sschaefer3's Avatar
You only need like 1/16" of clearance, the diff should not move much. I would use a grinding/sanding disc to knock it down a hair.
Old 08-25-2007, 11:19 AM
TC4RNR's Avatar
i'm goint to paint my later today. i was planning using spray paint stuff from homedepot, but do you guy think it's a good idea to paint in with spray-on bedliner? it's supposed to be alot tougher than the regular spray paint. wish i could powder coat it.
Old 08-25-2007, 06:52 PM
nmtoy's Avatar
Check the other IFS truss thread, I used spray on bedliner because it's what I had. I don't think it's any more durable than regular paint.
Robb
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
nick9455649
09-11-2015 05:10 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: would any of you post a write-up on how to install the sonoran steel truss?
