Winching Questions
Winching Questions
I just installed my new WARN 8000 and have a question. Should i leave the motor running while winching, the book said not to. but i think it would help keep from draining the battery.
I always leave my truck running when winching and I am running my winch off an auxiliary optima blue top battery. With the truck running, you are able to help the winch along by having the truck in drive while you're winching (depending on the situation you're in). The battery voltage will also be slightly higher (15% or so) with the truck running, which will cut down the amps that the winch draws.
They don't want you to do something dumb while winching, like use the winch as a tow strap too...it's a liability issue, they're just protecting their hides.
Question though, Warn seems to be the industry leader and standard in winches, but it looks like there's a lot of winches to choose from these days. Anyone used another brand (besides Ramsey, I like them too) and have anything to say?
Plus if the engine is running, people might put an Auto in Park and not Neutral.... Not good while it's getting pulled along with a Winch.
But I guess someone could do that while it's off too lol.
Maybe it's because on older Vechicles, running the motor while whinching might cause the Electrical System to overheat? Spark? I mean you choose your potential disaster.
In the end it's all about lawyers.
Like I said, I can see NO reason to turn it off and TONS of reasons to keep it running...
i love my dayton its a good winch i always leave my truck running while i pull if you turn your truck off to winch someone will be pulling you out of where ever you are and trust me tow truck drivers hate when you get there trucks dirty
So to go along with this, I have a Warn 800 on my Runner and it's kind of beat up, and been exposed to the elements for a long time. I picked up the truck a couple of months ago and it's been used before (the line is crap, fraying in places).
Anyone ever changed a winch line? Cant be that hard right?
Anyone have a Warn 800 Remote lying around that they'd want to get rid of?
Tree savers are cheap, there is no reason to be putting bare winch line around a tree in a recovery situation. They can also be used to wrap around a bumper if you're like me and have friends that don't have any tow points on their rigs.
agreed, i cant stand when people wrap their cables around bumpers or trees. damages the tree and kinks the line.
In many cases, it will kill the tree. If you cut through the bark on a significant portion of the circumfrence, the tree will die. I think it's called ringing the tree.
