Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
What do you do about antenna's?
i took the yota out for the first time down a trail and i must have broken the ant. bracket cause it will now swivel around all over the place. i was thinking about those universal power antennas that go up and down.
| Sponsored Links |
#2 (permalink) |
i busted 3 power antennas so finally i shaved the old location and i have a 5 foot CB whip mounted in the bed horizontally parallel to the back window,
its hidden but still visible,not to mention the killer reception ![]() |
#3 (permalink) |
I run the stock power antenna on my '85 and it works fine. Broke it one time on a steep gravel road, did not think I was in any trees, but one must have been close enough to the road. I like the setup on the earlier trucks, the antenna control is via a separate switch so you can have it up or down independent of the radio. Actually pulls in a decent signal even fully retracted. Another option would be one of the short rubber whip antennas, or a CB antenna as mentioned above. You can run a splitter on the antenna is you use it for both CB and AM/FM. For a CB antenna, be sure to run a spring on the base:
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler : 07-28-2008 at 10:53 AM. |
#4 (permalink) |
eighty5, can you post some pics of your setup and maybe a quick how to?
#5 (permalink) |
i just put a cheap $6 Autozone on my 01 Runner. Cant stand the up, down, up , down of the stock crap and plus the teeth messed up anyways so it grinded all the time. Im happy with it for $6
__________________
2001 4Runner 4x4 V6, 3" Revtek, Skyjacker Nitros, Hella 500's, 15% tint |
#6 (permalink) | ||
I took the ant off a junk blazer I had, and jammed it in the hole...problem solved..lol
__________________
Quote:
Quote:
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting DD: 94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock Project: 91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock. It's becoming an addiction. |
#7 (permalink) |
Any power antenna can be operated remotely with a switch instead of using the radio. You just have to wire it that way. Serious off-roaders hitting tree limbs and stuff might consider a power antenna to retract and put a small cage gaurd around the base of the antenna on the fender to shed limbs.
__________________
Kristopher Erik "KD5EJO" Transplanted Alaskan in Foster OK 88 X-Cab, 87 T4Runner Like Fishing, hunting, Ham radio, flying, canoeing, kayaking, traveling, all the better with friends. Dedicated Christian. Excellent Wife. 3 Very Good Sons. Any other questions? |
#8 (permalink) |
2 things I did to 2 of my trucks:
1. I bought a $10 antenna that you tape around the inside of the windshield corners. It works okay even in those low laying areas. 2. I pulled of the ball of the end of the antenna, then shortened the antenna below the cab line, grinded the tip fit the ball with epoxy glue. Still get pretty good reception. |
#9 (permalink) |
Antenna's????
__________________
94 4Runner 4x4, V6 Auto, Outlaw II's with BFG 33x12.5x15 on stock suspension (no lift), Kenwood KDC-MVP Sirius/MP3 player, Bushwacker extenda-flares, 1700 watt power inverter, Air intake mod, Radio Shack CB, GPS, Swing arm tire carrier, modified 1st gen Toyota 4Runner Rollbar, Aisin manual hubs. Off roading Rocks! |
#10 (permalink) |
I put a switch inline on the blue antenna wire. That way, when the switch is "on" the antenna is up when the radio is off. When the switch is "off" the antenna is always down.
__________________
JASON 1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny 31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR |
#11 (permalink) |
im actually thinking about buying a black rubber/plastic shorty antenna. maybe 8 inches or something.
#12 (permalink) |
I mounted one from a Ford Focus up on the front of the roof -got it from a junkyard for $10 -base, whip, and antenna lead. Real easy install: drill a hole, remove inside rear view to get at the backside, tighten everything down with a bit of black RTV to seal it and run the wire
__________________
'88 4runner SR5 - 3.0 7MGE eng swap - Marlin HD W56 - 4.56 V6 Thirds - '82 Toyota Celica Supra LSD up front - 32"x11.5" BFG AT KO's - NWMP Aux Gas Tank - home fab front and rear bumpers - Hannemann fenders "Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond |
#13 (permalink) |
Is there a windshield available for our trucks that has the antenna built in it?
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Question about CB antenna's | Mtriple | GPS & Communication | 7 | 04-18-2007 12:05 AM |
| Trying to tune duel antenna's (buddies rig) | SC4Runner | GPS & Communication | 2 | 06-12-2006 03:29 PM |
| My antenna's fixed! | WVRunner | Off Topic Talk | 2 | 04-27-2004 10:17 AM |
