YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-07-2008, 05:33 AM   #1 (permalink)
80yotaman's Avatar
Welding Rear end?
Im a good welder, and i was wondering is there any special technique that i would need to do as far as welding the spider gears up in a toyota 8" rear end. Need some answers quickley, Any advice would help out alot, Thanks
80yotaman is offline
Sponsored Links
To remove this ad, register today!
Old 10-07-2008, 05:47 AM   #2 (permalink)
WFO
WFO's Avatar
I just did mine a few weeks ago. I put the whole third member in my grill and let it sit in there for about 10 mins or so (about the time it took to get everything set up and ready) then just welded the gears where the come together. Just take your time and go slow. Then when its done put it back in the grill and let it cool slowly.
Ive seen a lot of different ways of doing it. Like filling all the teeth in so the gears cant move, welding a piece of flat bar onto the teeth or even welding another spider gear onto the gears.
But so far so good for mine just welded together.
WFO is offline
Old 10-12-2008, 01:08 PM   #3 (permalink)
n16ht5's Avatar
Send a message via AIM to n16ht5
do a complete job and make sure you weld the spider gears to the outside and not just to eachother.
clean out the slag... it will ruin your seals if you dont
__________________
photos.chrisneibauer.com
- Truck Photos
chrisneibauer.com
- My Photos
Alpentalic
n16ht5 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Welding my 83 front and rear ryanflknr Pre 84 Trucks 12 07-21-2008 07:29 PM
From rear bumper to welding cart tortis The Fab Shop 6 02-15-2008 03:40 PM
swapping out V6 rear end to 4cyl rear end 89yota_mudrunner 86-95 Trucks & 4Runners 11 02-07-2008 08:46 PM
Pros/Cons of welding rear diff Extremesolo Offroad Tech 10 02-10-2005 06:05 PM
Rear ABS - sensor on rear end housing? sarasota4runner 95.5-2004 Tacomas & 96-2002 4Runners 3 06-18-2004 09:25 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
