Warn M8000 mounting bolt sizes?
I recently bought a Warn Winch from a fellow YT'er but the mounting bolts were not included. So I would like to know what size bolts this thing needs. It will be installed in a TJM T-17.
Any help would be great!
-Casey
-Casey
Originally Posted by Good Times
you get your truck back yet?
Lookin to get a chance to wheel it on something worth while to test out the crawler.
I found it in my installation instructions. "3/8 x 1 1/4 grade 5 hex head capscrews, lockwashers and square nuts for a 3-16" to 1/4" thick mounting plate. (Cavities have been provided in the drum supports for the square nuts) " The square nuts are because you can't get a wrench on them.
For mounting feet forward on the TJM T-17 you will need a little longer bolts for the 2 bolts that go through the fairlead, Warn says to use "3/8-16 x 1 1/2 grade 5 hex head capscrews with lockwashers through the fairlead" I upgraded my bolts here to grade 8 when I did my install. I always go with grade 8 so I can torque them tighter.
kgcwb44
01-29-2023 10:02 AM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
whereAreMyPants
07-22-2015 03:32 AM
