| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Trd locking differential question.
#2 (permalink) |
not 100% sure on this, but look for something on here called the brown wire mod... i beleive it is a way to have 4x2 low range... not sure about the locker engaging situation though, most lockers are either on or off... not dependent on 4x4 or 4x4 lo... however, toyota may have put in a safeguard
#3 (permalink) |
I may be wrong, but I dont think you're supposed to go more than 5 miles per hour with the rear differential locked, it's to be used only when needed.
__________________
---Ryan--- 1999 V6 2WD (locked) Tacoma Prerunner |
#4 (permalink) |
Look at Customtacos.com you can find info about the locker mod.
#5 (permalink) |
Just look for information on the "Grey" wire mod.....
E-Locker ECU located under the driverside kick panel, run a jumper from the grey wire and ground it...... |
#6 (permalink) | |
Quote:
Modding it will likely invalidate any warranty you may have on the system, but it is totally safe as long as you're careful about engaging it. Just don't try to do so when you have a wheel slipping. Instead stop or at least slow enough to stop the slipping and then do it.
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!" |
#7 (permalink) | |
Quote:
__________________
#8 (permalink) |
Here's a nice write-up: http://www.offroaders.com/info/tech-...oma_locker.htm
Ground the grey #8 wire and you're good to go in 2wd. I think wire #10 is the one that goes to the speed sensor - ground that one and you can engage at any speed. I use my e-locker in 2wd all the time, but not for drag racing. It's fun to tell folks you didn't need to even put it into 4wd to get over the obstacle they struggled with.
__________________
Jay - 97 4Runner SR5 V6 Auto Air/E Lockers, OME, Revos, ARB bull bar, Superwinch X9, sliders, etc . . . |
#9 (permalink) |
Grey Wire Mod
__________________
Metalhed Rock on Dude! 2001 Red Tacoma, Supercharged, Auto 2" OME lift in front and AAL in the rear |
#10 (permalink) |
yes, grey wire mod. I've done it, it works fine. Of course I've only ever used my locker while I was actually in 4WD low, but I still like having the option.
http://www.offroaders.com/info/tech-...oma_locker.htm I think this is the same link as previously posted, but it is the instruction I followed. |
| Tags |
| 2004, adding, diff, differential, engaging, fast, interlock, lock, locking, low, rear, tacoma, tocoma, toyota, trd |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Locking Center Differential | Lefty | 95.5-2004 Tacomas & 96-2002 4Runners | 32 | 05-23-2009 03:26 AM |
| What locking differential would you suggest | SWOULTER | Offroad Tech | 27 | 12-02-2005 05:13 AM |
| Locking differential 3rd member | WVpizzaguy | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 11-01-2005 02:10 PM |
| Just a question about locking rear differential? | alltheway | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 05-27-2004 12:23 PM |
| how much $ for a true locking differential? | baileymoto | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 04-22-2004 02:32 PM |
