Trail gear dual case adapter - needle bearings
I recently killed a g52 5 speed and I'm in the process of moving my dual case setup to a w56. Everything came apart easily and everything looks really clean. No metal or pieces in the bottom of the case or on the magnetic drain plug. My problem is the needle bearings on the trail-gear dual-case adapter are no longer in their cage. Does anyone know the part number or vendor for these bearings? Also, I assume they are removed and installed like most other bearings.
