YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-23-2008, 06:11 PM   #1 (permalink)
SpecialScottie's Avatar
torque converter?
I have a 85 4runner which im currently in the process of an engine swap.
While the engines out I was wondering if it would be bennificial to install a aftermarket torque converter? Or should I just stick with the stock one?
Ive heard of guys increasing their low end power and gas milage is that true?
I searched but didnt find much
Thanks
__________________
1st gen 4runner interior for sale here
87 Turbo 4runner STOCK
85 4runner Build Thread
87 4runner (parts)
95 4runner 2wd auto
SpecialScottie is offline
Sponsored Links
To remove this ad, register today!
Old 07-23-2008, 07:20 PM   #2 (permalink)
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Depends on how worn out yours is, and what sort of "Aftermarket" part you are talking about.
A performance one? or just a stock one?
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by Junkers88 View Post
Good lord this thread is like herpes. Everytime I think it's gone there's another outbreak.
Quote:
Originally Posted by Sin91
If i am awake, I am horny; ask Abe!
DeathCougar is offline
Old 07-23-2008, 07:41 PM   #3 (permalink)
texcat101's Avatar
I changed mine as it had 200K on it while I had it out and put in a good rebuilt, there were significant changes in the way they bonded the friction material and the oem converters were inferior in this respect.
If you can afford it change it.
__________________
85 4runner, 22re, 3" spring lift, Precision Gear 5.29's w/power brute posi frt & rear, Mickey Thompson Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors '94 calipers and booster.
4.3 / 700r4 swap in progress - MORE POWER
http://i304.photobucket.com/albums/n...01/43v6007.jpg
texcat101 is online now
Old 07-23-2008, 07:57 PM   #4 (permalink)
How much $ are we talking?
Did you notice a increase in power?
__________________
87 4runner (parts)
95 4runner 2wd auto
Old 07-23-2008, 08:17 PM   #5 (permalink)
texcat101's Avatar
$180 -200 for rebuilt from autozone and it does seem to help on power. if you get a rebuilt make sure you take your flywheel bolts when you pick it up. some of the later models had 9mm bolts = good luck finding those.
__________________
Old 07-24-2008, 01:13 PM   #6 (permalink)
I noticed you also have 5.29's with 31's. Doesnt this give you high rpms on the highway?
__________________
87 4runner (parts)
95 4runner 2wd auto
Old 07-29-2008, 03:26 PM   #7 (permalink)
texcat101's Avatar
Quote:
Yes, about 3100 rpm's at 70mph. so with the 31's i had to run 65mph, But
I just put 33's on ( check my sig ) and that gets me close to 70 miles per hour in the 2700 rpm cruising range. My speedo is wac so I have to check it w/GPS.
Not ideal but with the 22re I would rather cruise slower and still have some power. It's not my DD.
Next year I may do the 3.4 swap.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Funky torque converter mycho 95.5-2004 Tacomas & 96-2002 4Runners 1 12-05-2007 07:46 PM
torque converter picture cruisinforburgers 86-95 Trucks & 4Runners 0 05-17-2007 03:44 PM
Torque Converter tampabayota General Vehicle Related Topics (Non Year Related) 8 03-12-2007 03:12 PM
Could this be the torque converter? Del General Vehicle Related Topics (Non Year Related) 1 01-01-2006 03:17 PM
Torque Converter Lockup 93ToyKid 95.5-2004 Tacomas & 96-2002 4Runners 9 03-17-2005 05:50 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
