Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Suspension Lift Question
Do I really need to buy a full lift kit for an 84/84 truck? Or can I just buy some new marlin (or any other nice brand) leaf springs, and some bilstein 5100 shocks?
That would save me a bunch of money. Sorry if this is a n00b question... Thanks! ![]() |
| Sponsored Links |
#2 (permalink) |
AFAIK you'll have to weld new spring hangers on the rear because the rear leafs are longer.
In the front you'll be fine but you won't have hi-steer. You could make it in parts, now the leafs and shocks, later the hi-steer and IFS steering box, etc... David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write... |
#3 (permalink) |
Define what you mean by "full lift kit" and how much lift you are looking for.
http://www.4crawler.com/4x4/4R_suspension.shtml
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) | |
Quote:
#5 (permalink) |
If you go with a mild 2"-4" lift and stick to stock length springs, you can get by with springs and shocks. If you want more lift or a higher performance setup, then longer springs, new hangers/shackles, shock mounts, etc. (i.e. a full lift kit) are likely needed.
__________________
#6 (permalink) |
What are some good springs that will fit the stock mounts?
#7 (permalink) |
i just put on a 3 inch springs 2 inch shackles fron and rear w/ pro craps and 35s and i extended the brake lines using 2wd rear brake lines from the junk yard and she wheels just fine.....w/o hi steer, gearing, etc. you limiting the performance of your rig tho! i just wanted to get her up tho...im gunna finish her later tho!
#8 (permalink) | |
Quote:
Did you use them front and back on yours or just back? ![]() |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Suspension lift question | mr_schuster | 86-95 Trucks & 4Runners | 15 | 03-14-2008 08:29 AM |
| 85 toyota pickup suspension lift question | corvettelvr73 | 84-85 Trucks & 4Runners | 8 | 05-09-2007 10:20 PM |
| IFS suspension lift owners question | mt_goat | 95.5-2004 Tacomas & 96-2002 4Runners | 22 | 08-03-2004 10:40 PM |
| Front end suspension lift question | SC4Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 08-01-2004 07:52 PM |
