YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-28-2005, 09:22 AM   #51 (permalink)
I Have Purchased An Ome Suspension Lift On My 2002 4runner. I'm Trying To Figure What Size Tires I Can Get Under It. Everyone Has A Diffrent Opinion. I Am Running 31x10.5x15's Want To Stay With A Narrower Tire And The 32's All Seem To Be 11.5 Or Wider. Will A 33x10.5.15 Fit Under My Truck Or Will I Need To Do Any Additional Modifications
DIRT is offline
Sponsored Links
To remove this ad, register today!
Old 10-28-2005, 09:48 AM   #52 (permalink)
Robinhood150's Avatar
Send a message via AIM to Robinhood150
Read the first post.
__________________
Steve. '93 4Runner V6 Auto 4x4
Robinhood's Lair. || Gettin' Off 4wd Club member
Lots for sale:5.29 ARB IFS third member... Click
Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in:
a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat...
Lesson...Stay on the TRAIL!
Robinhood150 is offline
Old 10-31-2005, 06:31 PM   #53 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Steve, can you just please delete the posts of folks just asking questions...to eliminate the clutter. Thanks...and delete this post too when you get r dun.
waskillywabbit is online now
Old 11-08-2005, 02:19 PM   #54 (permalink)
HOJU's Avatar
Interesting thread! I run a pretty cheap setup.
Front
- OME 882 Coils
- OME Firm shocks
- ATS A-arms
- Revtek Diff Drop Kit
= about 3.5" of lift but has sagged to 2.75-3"
Rear
- OME 891 coils
- OME Firm shocks
- OME 5mm trim packers
= about 4+" or lift, but with a roof rack, bumper and stereo it's now at 3.5"
Tires - 285/75R16's
I've since added a Roger Brown 2"BL and have 35's now. I plan on swapping out the trim packers for either OME 892 coils or just add some cornfed spacers
__________________
Allen-
"You'll have to speak up, I'm wearing a towel..."
Return With Honor
HOJU is offline
Old 12-29-2005, 09:42 AM   #55 (permalink)
GodwinAustin's Avatar
97 Tacoma
OME 880 Coils up front (approx 1" lift)
OME "firm" N91s struts
Deaver 3 Leaf Progressive AAL (approx 1.5" lift)
OME N85 rear shocks
With about 1" of lift I am running 32x11.5 Dunlop MTRs and they fit great, with just a little rubbing on the mud flap @ full lock or while hitting bumps and turning. Now, I know most people say to run 2" of lift to fit 32s but I didnt want to put the stress on the CVs and front IFS etc so I ended up going with the OME 880s instead of the 881s or 882s. I think the TJM up front helps with clearance issues with so little lift....I have not wheeled the truck yet with this setup - but I have a good amount of clearance overall.
edit: removed the mud flaps minimized rubbing issues. Small amount of rubbing when suspension is compressed and truck is in reverse, also some rubbing during hard hits on the front ifs while turning. Nothing too bad. Removing the mud flaps really makes the truck get alot dirtier - espescially up here in NH - road salt is EVERYWHERE and the truck is constantly covered in it.
With the 32s (up from 31s) I have lost about 3 MPGs or so. Previosuly I got between 300 and 315 per 16 gallon tank. Now I am getting about 250 miles per tank. About 18-18.5 mpg previously - now I am averaging around 16MPG.
__________________
-Jon
85 4Runner - 5Spd - 3 inch Downey spring lift - 2" body lift
GodwinAustin is offline
Old 04-18-2006, 10:25 PM   #56 (permalink)
KyleT's Avatar
I run the TRD OEM Tundra/LC setup, I purchased the "kit" from Steve at Sonoran Steel for the ease of not tracking down everything myself. it included the panhard drop bar, longer rear brake line, lswaybar mounts, bumpstops, diff drop, all the shocks and springs and one spacer for each side in the front. and im probobly forgetting something else too.
I have Lexus GX470 rims, 265/70r17 tires and 1.5" bolt on wheel spacers. I also have 1 spacer ontop of the front shocks.
__________________
- Kyle
Former Owner of -
1996 Sunfire Red Metallic 4Runner Limited updated 10/31/06
OEM/TRD Lift Kit #1 from Sonoran Steel with 1 Top-out spacer - Lexus GX470 rims - 295/70r17 Nitto Terra Grapplers Yukon 4.88's, E-Locked Rear, Waiting to blow up front diff #2
KyleT is offline
Old 05-16-2006, 06:04 PM   #57 (permalink)
Tacoma Lifts
Quote:
Originally Posted by GodwinAustin
any links for 4x4 Tacoma Lifts pleasssssseeeeeee
Check out this Tacoma Section.
Mangone is offline
Old 08-04-2006, 06:21 PM   #58 (permalink)
Total Chaos makes some great IFS suspension kits:
http://www.chaosfab.com
DilutedImage is offline
Old 12-29-2006, 02:09 PM   #59 (permalink)
86 toyota pick up
Total chaos uniball kit $3400
Fox shocks 2.0 10'' coil $1000
Downey rear springs $185 with 2.0 8'' fox $200
prp seats Iven glass
Under cunstruction
Leonardo Muniz is offline
Old 12-29-2006, 02:10 PM   #60 (permalink)
I got one 2wd
Old 06-11-2007, 04:29 PM   #61 (permalink)
apalmer1's Avatar
Donahoe racing 3" lift extended travel coilovers, flex like a champ with swaybar off, take ANY amount of air or abuse smoothly without damage or bottoming out, fully rebuildable. As for the back, im ordering a 1.5 inch lift AAL to increase load capacity and height a little, and to get the blocks out, then im also going to do 1.5" longer greasable shackle hangers to give me more flex and compensate for the small amount sacrificed by the AAL.
apalmer1 is offline
Old 08-22-2007, 07:16 AM   #62 (permalink)
Tacotex's Avatar
I think there's a lot to be said for staying within a 0 - 3" range of lift, with 2" - 2.5" being the best bet for a rig that is mainly a DD. I can do 90% of what the taller trucks can do, and I've made it up some obstacles that left a Taco with nearly 3 times my lift and 35 x 12.50 tires stuck behind (muddy climb out of a ravine). I see some guys that lift their rigs and forget that they need widen their wheel track in proportion to their lift to offset the increased risk of rollovers (which can do a lot worse than total a rig). I've been a passenger in a highway rollover and it's not something I'd like to do again. Personally, if I decide I want to hit the type of extreme rock crawling that requires big clearance and articulation, I would go with a dedicated trail rig-probably built on a beater or tube chassis. To each his own of course-just my :2cents:
BTW-Lots of good info on aftermarket suspension here: http://ttora.com/
I'm waiting on my Alcan 2" custom springs for the rear
__________________
Pete
'04 Taco TRD SR5 4x4 3.4L 5spd, Donahoe coilovers, custom Alcan springs & Bilstein 5100s, 16x8 steelies, deckplate mod, free alarm mod., 265/75/16 Nitto A/Ts.
'98 4Runner SR5 3.4L auto, Bilstein HDs, 31x10.50 BFG ATs, airbox elbow mod. 235K+ & going strong.
Tacotex is offline
Old 08-22-2007, 10:53 AM   #63 (permalink)
tacoma728's Avatar
i am utilizing a revtek 3" suspension lift that gave me an additional .5" of lift in the front. Really helped on trails. I reneged on the diff drop. It's not necessary. I have wheeled the crap out of my tacoma with absolutely no ill effects. The revtek is complimented by a 3" bodylift which has been great for improving approach and departure angles.
__________________
Every 4x4 i own is sold, moved on to an economical car. SEE YA
tacoma728 is offline
Old 10-20-2007, 05:51 PM   #64 (permalink)
mtespey's Avatar
Cool 88 two wheeler
My 88 truck recieved a new Downey suspention lift with heavy tortion bars new a-arms, new shocks and now Im breaking the shock mounts on the bottom. The new shocks seemed shorter than stock so I replaced with longer ones and still have the same problem. Any help is appreciated. Mike
mtespey is offline
Old 10-23-2007, 03:49 PM   #65 (permalink)
99 Coil springs
I know that the 99 4Runner front springs are higher then all the other 3rd gen 4Runners, but are the rear coils higher to?
sniperwolf is offline
Old 12-09-2007, 06:59 PM   #66 (permalink)
881stGenRunner's Avatar
bump...
__________________
-Brandon
1988 4Runner SR5 4x4 V6 5 Speed Swap SDORI 1.5" BJ Spacers~Downey 26MM TBs~Downey 3" Springs~Downey Shackles~PC ES3000s~PC ES2000 SS~Motive Gear 5.29s~Rear Detroit~Front Lock-Rite~Yakima Load Warrior~33x12.5R15 Yoko Geolander M/Ts~Cragar 15x8 Streetlocks~Cobra 18 WXSTII~3' Firestik II~Marlin Crawler rear~Custom Front~4X Innovations Sliders~WabFab Bikini Kit~Optima Yellow Top~SS IFS Truss.
My 4Runner and Other Stuff
881stGenRunner is offline
Old 05-18-2008, 06:56 PM   #67 (permalink)
mikeweber32's Avatar
Send a message via Yahoo to mikeweber32
I have looked every where and i have been unsuccesful in findin a suspension for my toyota t100 with 2wd. i was wondering if anyone knew where i would be able to find one. Also if they dont exist, wut can i do to lift it other than 3 inch body lift?
mikeweber32 is offline
Old 05-18-2008, 08:38 PM   #68 (permalink)
Tacotex's Avatar
Quote:
Here's a T100 transformation: http://www.ttora.com/forum/showthread.php?t=76817
__________________
Pete
Tacotex is offline
Old 11-08-2008, 01:29 PM   #69 (permalink)
SR5
SR5's Avatar
the one i made, LOOOOOOOOOOTTTTTTTTTSSSSSSSSSS of INFO
http://www.yotatech.com/f116/2gen-4r...-guide-155339/
__________________
1995 SR5 V6 4Runner
SR5 Profile
|31x10.50 BFG All Terrain|Diff Breather Front, Rear|Low Profile bump stops|Blue LED Dash|Japan Running Lights|Alpine Deck|Custom 6.25 Sony 4 Way Rear Speakers|4" Alpine Front Speakers|
SR5 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
