Stock sway bar mounts
Old 01-18-2016, 09:14 AM
garagespace's Avatar
Does anyone have the stock rear sway bar frame brackets off a 84-89 pickup? i have a 1986 toyota pickup sunrader rv with a dually rear 1 ton axle but the last owner took off the stock sway bar frame mounts for some odd reason. mine were bolted to the frame but here is a pic showing them welded.
i am hoping someone out here has an old frame for parts they want to cut off/unbolt and sell.
here is a pic of what im looking for.
Attached Thumbnails Stock sway bar mounts-screen-shot-2016-01-12-2.18.59-pm.png
Old 05-25-2016, 07:49 AM
sway bar
anyone know what part number or what yota this sway bar is off of ?!<br ><br >
Old 05-25-2016, 05:23 PM
highonpottery's Avatar
I'd look for a DIY part instead of someone cutting off a bracket for you to use. Maybe a body mount would work for that, or a shock mount of some sort. Heck you could even hand fabricate that bracket. Contact some companies that make weld-on parts and inquire, such as Ruff Stuff.
No idea what that swaybar is off of - maybe one of the 4Runner generations?
Old 05-25-2016, 11:25 PM
wyoming9's Avatar
I would venture it is made just for the RV set up and no doubt added when the complete unit was finished .
Make your own or have a local fab shop make them.
None of the Toyota`s I have worked on have a sway bar set up like that
Old 05-26-2016, 03:20 PM
osv
osv's Avatar
i got those sway bar brackets off of an early '90's(??) 4runner/pickup, in the junkyard, they are bolted on.
Old 05-26-2016, 11:42 PM
wyoming9's Avatar
I think the brackets might be off the second generation 4Runner
None of my 86/88 pick ups have a rear sway bar.
Did they from New ??
Old 08-22-2019, 08:02 AM
i found these brackets on a 92 4 runner and they were bolted to the frame. not sure why some years they were welded and some bolted.. Maybe it was a dealer add on.
If anyone has a stock 1 ton rear sway bar off a dually cabin chassis to sell - please DM me
brassmonkey001
9
02-04-2018 03:22 PM
ManyMods
107
09-08-2010 07:59 AM
WillRadford
03-26-2009 09:18 AM
BajaRunner
15
03-15-2006 09:25 AM
Quick Reply: Stock sway bar mounts
