Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
spring bushings
on my truck i have the all pro 6 inch lift long travel leafs up front, which i am very happy with. when i ordered them i also ordered their shackle kit too just to save time and it was greasable and everything. the bushings have been on the truck for about 4 months now and they were pretty much worn out, i had a death wobble problem that started so i replaced the bushing with the set that came with the leafs and its fine again now but i was wondering if yall are having these problems and how yall are fixing them, maybe someone makes a firmer bushing or something.
| Sponsored Links |
#2 (permalink) |
Make sure the shackle side plates evenly contact the lip of the bushings and are not hitting at an angle as that can chew up the bushings in short order. Also, w/ greaseable shackles, use only polyurethane bushings. I generally get many years out of a set of front bushings on my '85.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
i think you're right the the rear bushings on the spring hangers(shackles in front) aren't perfectly square, ill straighten them out and see what that does for me. thanks for the help
#4 (permalink) |
lithium grease on poly bushings works great too
__________________
1984 toyota sr5 4x4 22r w/ weber 32/36 Pro comp 4" front springs and 3" rear downey springs D-tech Shocks 33x12.5 M/T , 15 inch weld rims Hella 550/ Hella h4 conversions with HID Home made On-board air system |
#5 (permalink) | |
Quote:
If your spring hangars arent straight you'll go thru bushings very very quickly! That could also be the source of your death wobble
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#6 (permalink) |
the springs are square, just the tabs that drop form the frame where the leaf spring attaches on the fixed side are more like \ / in stead of l l so ill straighten them out and see where that gets me, i appreciate the help ya'll!
#7 (permalink) |
Could also be the spring hangers are built for a different width spring than what you have in there. When I built my front hangers, I made them wide enough to handle a 2-1/2" wide spring even though my Toyota springs were 2-3/8" wide. I just slip in a washer on each side of the hanger to take up the gap between the hanger and the bushings.
__________________
#8 (permalink) |
well i built the hangers for the Toyota springs but i guess when i welded it on the sides of the hanger pulled in, i didn't look real bad to me though so i left it. in the rear one of my spring hangers is bent from a rock and ive never had a problem with it. those are also non poly urethane bushings, so they are a little stiffer. i ordered new bushings from all pro and as soon as they get here i will be straighting them out and seeing if that fixes my problem. which from the looks of it it should
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| IS it worth it? spring & shackle bushings? | ogclew | 86-95 Trucks & 4Runners | 4 | 05-02-2008 02:42 PM |
| Stock Springs Or Spring Bushings | myyota | 84-85 Trucks & 4Runners | 8 | 07-06-2007 08:38 AM |
| 1st gen shackle and spring bushings...options | thook | 86-95 Trucks & 4Runners | 12 | 05-04-2007 06:29 AM |
| question about new shackles + leaf spring bushings | isaac338 | 86-95 Trucks & 4Runners | 17 | 12-30-2006 04:09 PM |
| leaf spring bushings | Robert m | 86-95 Trucks & 4Runners | 1 | 11-07-2006 06:11 PM |
