YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-07-2008, 08:03 AM   #1 (permalink)
Speed Sensor ...HELP!!!
i need help with finding a new speed sensor.... i am putting a 4'' suspension lift and 33X10.50 tires on my '88 4X4 extra cab pickup ........ my dad says that having the lift without a new speed sensor will throw off my odometer and screw stuff up so i need to find one ......HELP please
__________________
Nebrkid817
'88 4X4 Pickup Xtra Cab 2.4L 4cyl. 22RE w/ BFG All-Terrains
All Stock
Nebrkid817 is offline
Sponsored Links
To remove this ad, register today!
Old 06-07-2008, 08:36 AM   #2 (permalink)
PPPPLLLLLEEEEAAAASSSSEEEEE i need help ASAP
__________________
Nebrkid817
All Stock
Old 06-07-2008, 09:05 AM   #3 (permalink)
4Crawler's Avatar
Quote:
The real answer is to regear the axles for the taller tires. With a 5 speed tranny, 4.88s are just the ticket, with an automatic, 5.29s.
Likely with an '88, you have a mechanical speedometer, so the only other option is to get a ratio converter box froma speedometer shop. I used to run one and it cost about $100.
Also, don't need anywhere near 4" of lift for those tires:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
With the money you save on the lift, you can probably do the gears.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 06-07-2008, 11:01 AM   #4 (permalink)
where does the ratio converter box mount?
__________________
Nebrkid817
All Stock
Old 06-07-2008, 11:08 AM   #5 (permalink)
4Crawler's Avatar
Into the back end of the transfer case where the speedo cable attaches. Basically it is a little gear box, has a female metric speedo cable end that screws into the t-case and amale metric speedo cable end that the speedo cable screws onto. You run a calibration test for the odo and speedo to get the actual error in reading (with the new tires) and send that to the shop and then they make the box. I got mine about 10 years ago from NWOR, but they sent it out to some shop to make the box, so likely most any speedometer shop can do that. Also, there is nothing on these trucks that will get "messed up" if you don't recal the speedo, aside from the speedo and odo reading slow. You will lose driveability and probably gas mileage if you don't regear.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 06-07-2008, 04:57 PM   #6 (permalink)
4rnr's Avatar
Who cares!!!
your speedo will be off by maybe 5%, figure it out in your head as you are driving.
Oh and the lift has nothing to do with the speedo its the larger tires. To determine the difference use this formula (new size - orignial size = X ) then (X/original tire size = percentage that the speedo will be off.)
__________________
poop
1988 stock 4runner, v6, 5spd, soft top.
1990 fj62 stock and mint!
1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, custom snorkle, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Electronic shifters by AWshifting, Mcintosh/Dynaudio a/v system.
The build up...http://www.yotatech.com/showthread.php?t=74915
4rnr is offline
Old 06-07-2008, 05:04 PM   #7 (permalink)
4Crawler's Avatar
Assuming 28" stockers and going to 33s, you'll see about a 17%-18% error in the speedo (it'll read slower than you are actually going), so at an indicated 60, you'll be going nearly 71. Same on the odo, it'll under report distance traveled by the same factor.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Speed sensor or something else? Robinhood150 86-95 Trucks & 4Runners 41 06-09-2008 12:42 PM
speed sensor bronsonsteele 86-95 Trucks & 4Runners 1 02-10-2008 03:54 PM
speed sensor cat321 86-95 Trucks & 4Runners 4 05-01-2007 11:12 AM
speed sensor straightaxle85 95.5-2004 Tacomas & 96-2002 4Runners 3 08-19-2005 04:17 PM
Speed Sensor? 4RocRunner92 95.5-2004 Tacomas & 96-2002 4Runners 1 07-19-2005 09:23 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
