| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
setup recommendations
#2 (permalink) |
i would personally go as big a lift a lift as you want.... in your above named setup i would do downey 3" with downey 2.5" over stock shackles
wait a sec, are the 2.5" over stock shackles jsut longer by 2.5" meaning a 1.25" lift? or are they 2.5" lift shackels meaning 5" longer than stock? i would personally not lift anything over 2" with shackles (4" longer than stock) |
#3 (permalink) |
i think the shackles are 2.5" longer than stock, so a 1.25" lift
what i'm trying to avoid here is making the truck look too funky. but, i'm not sure exactly what difference between front and rear lifts would make it look weird. i'm all about functionality though, so if a minimal lift would have the same net abilities as a maximum lift, i'd have no qualms about playin it small |
#4 (permalink) |
I would start with one or the other. New springs are a good option if your old ones are sagging. 2" or 3" would be fine, a 2" spring will likely be softer than a 3" spring. If you find you need a little more lift after installing the springs or after the settle with time, then add the lift shackle. You can re-use the stock shackles if they are in good shape, no need to replace.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| New clutch - recommendations | maguirre | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 09-16-2006 11:30 AM |
| Exhaust Recommendations? | MAXIMUS1968 | 86-95 Trucks & 4Runners | 3 | 09-13-2006 01:43 PM |
| Hitch recommendations | Glenn | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 07-02-2003 10:07 PM |
| recommendations? | tigers | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-27-2003 09:43 PM |
