YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-03-2008, 11:48 PM   #1 (permalink)
Matt16's Avatar
SCUBA tank, on board air.
I have a York compressor almost ready to go on my truck. It puts out 7cfm (the big ARB puts out 2 or something), so I dont even really feel I need a tank, but I'm worried that the pressure release (blow-off valve?) won't handle 7cfm and the pressure in the hose will increase past it's capacity before the compressor can turn off. Thus, I want some kind of cheap tank.
I found an old SCUBA tank (about 2' x 9") at a junk store with the original fittings. Are these NPT? Its steel I believe.
The other tank I found was an old aluminum pressurized kerosene tank for a kerosene stove. Again, not sure whether the fittings are NPT, but at least it has a shraeder valve.
There was also an old medical oxygen bottle, NPT?
__________________
1990 Toyota 4Runner 22RE 5spd
Rear Aussie Locker [click here for the review] *Nokian Vativa A/T tires* OME suspension* York OBA* pretty much stock.
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Toyota FAQ link
More info on 4Runners
- awesome resources
Matt16 is offline
Sponsored Links
To remove this ad, register today!
Old 09-04-2008, 03:15 PM   #2 (permalink)
tc
tc's Avatar
Not sure on the fittings. You certainly don't need a tank that big (and the space it takes up)
What pressure does the York run at? Could be too high for lockers, and another regulator on the output of the tank would be a good idea.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 09-04-2008, 10:13 PM   #3 (permalink)
Matt16's Avatar
Essentially I am looking for the cheapest safe tank that I can use that will fit above my rear axle. The York apparently puts out a massive 7cfm at idle at 90psi. That's what I've heard. The only reason I want a tank is because I don't think any blow off valve (?) can handle that much air and I don't want my lines instantly exploding the second I stop putting air into the tires, before the pressure switch cuts power to the electro-magnetic clutch on the York.
With a larger system volume, the pressure will increase slower and the pressure valve will have time to turn off the compressor without a huge spike in pressure.
__________________
Toyota FAQ link
- awesome resources
Matt16 is offline
Old 09-04-2008, 10:16 PM   #4 (permalink)
Matt16's Avatar
A semi wrecking yard is charging $40 for a 2 gal tank, which is a little much I think. This is a jury-rigged, budget project, cause all the NPT fittings are going to be the expensive part.
__________________
Toyota FAQ link
- awesome resources
Matt16 is offline
Old 09-04-2008, 10:18 PM   #5 (permalink)
Im thinking of using an old propane tank for my york compressor. Just my thoughts
__________________
1994 Toyota 4x4 22re
premirrider is offline
Old 09-04-2008, 10:51 PM   #6 (permalink)
scuba's Avatar
Location: Selling turnips on a flatbed truck, I 15N @ 79S
Quote:
So mine got stolen not too long ago, im guessing that stupid crack junkie took it to whatever junk store you got yours from...
Could i by it back...
__________________
^Say GO DJ..Uh thats my DJ
The Blue Biche
91 4x4 p/u 22re--elbow mod, 500ff's. BFG A/T ta KO's. Smokey the Bear
I Work on my gas tank while smoking a cig...Sue me
Dad- 1999 4runner base 2x4, 2.7, 5speed, 52k, cherry.
Chat with meeee
Quote:
Originally Posted by 904_runner
Im still waiting for obama to redistribute the truck parts
Quote:
Originally Posted by Sin91
Technically I would have to share it with everyone who didn't have a beer if I was Obama
Pacific Crawlers
UltimateYota
scuba is offline
Old 09-05-2008, 12:02 AM   #7 (permalink)
Matt16's Avatar
That s a bit of drive to go from San Diego to Vancouver, but those crack heads are pretty determined.
Do you know if scuba tanks are NPT, seeing as you have some experience with them.
__________________
Toyota FAQ link
- awesome resources
Matt16 is offline
Old 09-05-2008, 01:39 AM   #8 (permalink)
taikowaza's Avatar
I'm a scuba instructor and you've got to be careful with those old scuba tanks. There is a date stamped on the tank itself, that is a hydrostatic test date, if it's over 5 years it's not considered safe for a fill.
I heard a tank blow (luckily no one was in the compressor room when it happened)...
it left a very large chunk out of the wall heheheh
but all joking aside take that tank to a scuba shop and get it 'hydroed' and visually inspected, they'll stamp the steel with the new hydro date and put a fill sticker on there good for a year until your next visual inspection and you'll be good to go!
__________________
92 4runner,Thorley Ceramic Headers,Stan's Custom Exhaust,OME Suspension,DowneyHDCoils,MarlinHD Clutch,PIAA520s,24/30"Magnaflow Muf/Cat,Warn Hubs,BudBuilt IFS Skid+Xmbr,Sonoran Truss,Odyssey Batt,33x10.5 BFG A/T,ISR Mod,Boyle's Alternator,TJM T-15,Demello Sliders,Warn XD9000,Dual 4.88 Truetracs,LCE bored TB,Weasy Cams,NWMP Xtnd Range Tank
taikowaza is offline
Old 09-05-2008, 03:57 AM   #9 (permalink)
crolison's Avatar
ditto, you don't wanna mess with a big flying hunk of metal in your truck.
__________________
97 4runner, 2.7 5speed 4wd, 4.556, 255/85/16 Maxxis Bighorns
rear diff breather, 4 hella 500's driving, sliders, wilderness rack
custom bumper
arb locked rear
toytec adjustables, ome 891's, bilstein 5125
manual hubs
broken front and rear swaybars
My Profile
crolison is online now
Old 09-05-2008, 04:20 AM   #10 (permalink)
ETRNL's Avatar
kinda off topic but would a full Scuba (3000psi) be safe to drive from 4500ft to sea level mounted in a vehicle?
mine is for on board air as well but i use an adapter for a paintball tank to a 48ci (regulated to 800psi)tank to an external regulator set at 100 psi to standard yellow coil airhose to fill tires
__________________
2001 4Runner LTD, ISR/deckplate/ECT mod, 6K HIDs, 12g headlight wire harness, Satoshi, Hood Emblem, fog light mod, constant power mod, NO DRLs, Remote start with ~1 mile range.
my favorite video
ETRNL is offline
Old 09-05-2008, 05:19 AM   #11 (permalink)
crolison's Avatar
Yes, 3000psi in a tank is still 3000psi wherever you go, since it's its own atmosphere, and is not affected by the outside pressure (unless its a crap load of pressure or vacuum).
__________________
custom bumper
arb locked rear
manual hubs
My Profile
Old 09-05-2008, 07:47 AM   #12 (permalink)
taikowaza's Avatar
pressure
Quote:
yes this is correct, the pressure in the tank will be almost identical but the change comes in when ambient pressure kicks in, IE when you start breathing or using the air...for example if you are very deep underwater you will burn through your 3000psi much quicker because the air is denser (more molecules of oxygen/nitrogen in each breath)...so that's why you have to worry about oxygen toxicity and nitrogen narcosis the deeper you go.
so when you are high up in the mountains, there are other things to worry about with your tank and your body...for example, there will be a lot less oxygen in each breath as the molecules will be dispersed, so the higher you go, the less O2 is getting to your brain. That's why those Everest climbers need O2canisters to stay focused etc.
as far as wheeling at the ranges you're talking about this shouldn't be an issue at all, but if you ever plan on diving with that tank be careful not to drive up high into the mountains right after scubadiving, this is just like being in a plane and if you drive up too high soon after diving you will get bent
__________________
Old 09-05-2008, 08:33 AM   #13 (permalink)
4Crawler's Avatar
I think there may be some NPT fittings on a Scuba tank. I once did an air up system for a guy that works at a resort where they use those tanks and he wanted to be able to air up his tires from the high pressure tank. He sent me a 1/4" NPT fitting quick disconnect fitting that fit the Scuba regulator and I integrated that into the air hose:
- http://www.4crawler.com/4x4/ForSale/4air.shtml
Another option is a used pressurized water fire extinguisher. They are rated for 200 psi and made of stainless steel. They do have one 1/8" NPT fitting, but I drill and tap the head for 3/8" and 1/4" NPT fittings:
- http://www.4crawler.com/4x4/CheapTri....shtml#Storage
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-05-2008, 09:37 AM   #14 (permalink)
Matt16's Avatar
I'm going my a semi wrecker to look at air brake tanks today.
Given my situation described above, do I even need a tank?
The way I see it, a scuba tank rated to 4000psi isn't even going to notice 120 psi, even if it expired. If you disagree, please explain.
__________________
Toyota FAQ link
- awesome resources
Matt16 is offline
Old 09-05-2008, 02:59 PM   #15 (permalink)
Matt16's Avatar
Bought an air brake tank. Has the pressure release valve, the mounting bracket etc, as well as 5 NPT tapped ports. I'm pretty happy with it.
__________________
Toyota FAQ link
- awesome resources
Matt16 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Converting a SCUBA tank to onboard air or co2? 91 4Runner The Fab Shop 15 04-08-2005 03:20 AM
Air tank for on board air mtnbkr Offroad Tech 2 05-05-2004 06:42 PM
Scuba Tank loyota33 95.5-2004 Tacomas & 96-2002 4Runners 16 11-02-2003 08:56 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
