| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Sagging Rear Passenger? Any Help
#2 (permalink) |
Shock absorbers do just that, absorb the road vibrations. Springs support the vehicle's weight and thus control the ride height. One thing you might try is swapping the springs and/or shocks from side to side and see if the sag follows the spring or shock.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
Loosen all your link bolts (4 lower, 4 upper), bounce the 4Runner a couple times and then re-tighten. Maybe the bushings are set in the wrong place. It can happen if you tighten everything with out it being level.
__________________
Custom painter and Toyota Stripe and decal supplier. http://jamesdeancreations.com Custom Safari and Crawlin accessories. http://www.jamesdeancreations.com/4runner_project.htm Last edited by James Dean; 09-28-2009 at 04:25 PM. |
#4 (permalink) |
I hope this works. Im going to try the boucing idea first as thats an easy fix for me. As for swapping my springs side to side, well thats a harder fix but something i should be able to do. Very limited knowledge of taking things apart. I went ahead and bought an extra shock sense they are only 40bucks online anyways so will try that also. any recomendation on where to get 4inch lift springs for my 4runner besides procomps set if thats what i need to do?
#5 (permalink) |
You could search here for information on the "cruiser coil swap", using junkyard coils off an FJ80 Landcruiser for the rear of the 2nd gen 4Runner.
__________________
| Tags |
| 4runner, 94, bring, coil, drivers, fj80, junk, lift, needed, rear, sag, sagging, side, spring, swap, yard |
