YotaTech Forums
Go Back   YotaTech Forums > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Sign in using an external account
Register Forgot Password?
Search
SPONSORED BY:
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 08-03-2004, 04:08 PM   #1 (permalink)
Personal Sales Rating: (0)
MNBOY's Avatar
Removing axle shafts
I seem to remember there is some trick to removing the axle shafts without pulling the brake discs and everything. I just need them out far enough to remove the 3rd. I guess it's been a while since a had a solid axle truck, and the worthless Haynes manual skips righ tover this. Can someone post this so I have it when I get home. It's for an 85 Toy axle. Thanks.
__________________
____________________
Greg
MNBOY is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 08-03-2004, 09:31 PM   #2 (permalink)
Shane's Avatar
Send a message via AIM to Shane
Assuming stock drum rear brakes...
Drain gear oil
Disconnect e-brake cable from both sides
Disconnect and plug brake lines
Remove 4 nuts from back-side of brake plates
Pull axle shafts complete with brake assemblies out
I recommend pulling them all the way out when you do this, if not you may inadvertently crush the inner seals by resting the shafts on them.
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!"
Shane is offline
Old 08-03-2004, 09:36 PM   #3 (permalink)
Shane's Avatar
erm... you probably meant front axle, huh...
You can remove the steering arms which will allow you to pull the assembled knuckle off, but it can be a PITA both to get the birf lined up so it can come out and an even bigger one to get it back in. I'm not even sure that it's possible without the birf-inner-clip-eliminating-tack-weld mod.
__________________
Shane is offline
Old 08-03-2004, 09:45 PM   #4 (permalink)
Threadstarter [OP]
MNBOY's Avatar
yeah, front.
Now I think I remember. Undo the four nuts and damn cone washers on top but leave the bottom four alone. I should probably pull the whole thing apart and check out the bearings now that I think about it. Thanks though.
__________________
Greg
MNBOY is offline
Old 08-04-2004, 06:13 AM   #5 (permalink)
crawler#976's Avatar
Greg,
Quote:
The camo Method (from the Pirate faq's page-)
Pull locking hub cap and remove snap ring.
Unbolt seal/felts on back of knuckle.
Unbolt brake caliper and tie out of the way. (can be skipped if you have long brake lines)
Unbolt steering arm. (leave bottom knuckle cap alone)
Pull entire outer knuckle assembly off of axle.
Sawp in your parts.
Put it back together.
It's a big-time shortcut since you don't need to mess with the 54mm socket or wheel bearings.
note: I use a heavy duty bungie cord (or two) to support the assembly once it's off-
That is how I do it- but I also spend the time once a year to pull the whole mess apart to check bearings and get it lubed up. Also, I don't fill the knuckle full of grease- I use synthetic grease on the birf and a light coating on the knuckle itself. It's a PITA to deal w/ the mess- even w/ fresh inner axle seals, some 90W seams to get into the knuckle, mix w/ the grease and turn into a REAL mess. It is one of the reasons I carry the biggest trash bags I can find in the truck- if I pull the assy off on a trail it keeps the gunk off the ground.
Martack'd axle shafts are not required to dissasemble the front end this way. They help in removing a busted inner axle- since they seem to shear at the birf, it is easier to get out the stub if there is no retaining clip.
later
__________________
...down to the two Taco's, no more SloYota!
crawler#976 is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
assy, axle, back, knuckle, pull, rear, remove, removing, sealfelts, shafts, sienna, solid, tacoma, toyota, unbolt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Changing axle shafts 93toy 95.5-2004 Tacomas & 96-2002 4Runners 5 07-08-2008 04:33 AM
Looking for rear axle shafts for a '96 4runner??? Any websites??? ivanr 95.5-2004 Tacomas & 96-2002 4Runners 4 05-09-2007 12:26 PM
Write up on pulling axle shafts and rear third? KyleT General Vehicle Related Topics (Non Year Related) 13 01-04-2007 03:10 PM
Stock Tacoma 3rd and axle shafts shortbus The Classifieds GraveYard 5 06-29-2006 09:48 AM
how to change toyota axle shafts ?? wimpywade94 Offroad Tech 9 06-25-2003 04:11 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
