YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-20-2006, 08:10 AM   #1 (permalink)
vwfastg60's Avatar
Send a message via AIM to vwfastg60 Send a message via Yahoo to vwfastg60
Rear Spring Question
Is there a rear spring that i can put on the rear of my 87 truck that will lift it?I dont want to fab mounts like i was told i would have to do if i use K5 blazer springs but id like to get the back up.
something in the range of 4-5 inches would be nice
__________________
87 longbed on 36's*now with scrubbing bubbles*
86 SR5 2wd-soon to be laying frame under the 87.
vwfastg60 is offline
Sponsored Links
To remove this ad, register today!
Old 09-20-2006, 06:02 PM   #2 (permalink)
mikevyota's Avatar
Most suspension companies, Superlift, Skyjacker, BDS, offer stock length rear leafs for $200-300. They are short though, and with the arch built into them, you have to watch out for shackle inversion( when the shackle flips forward and prevents the leaf from moving back). If all you want is lift, then these are fine. Better than a block/add-a-leaf setup.
mikevyota is offline
Old 09-21-2006, 10:45 AM   #3 (permalink)
deathrunner's Avatar
I had the Skyjacker "Softride" 4" springs on my 89 4runner. I swear it was more like 5" of lift. The flex was pretty good. The ride was pretty tough. The price was upwards of 300 if I remember correctly.
Then I swapped to Downey 3" springs. Cost me 168.00, says 199 on thier site now. www.downeyoff-road.com
These are supposedly made by the same people that make teh stock Toyota springs. To get a true 3" of lift you need to re-use a leaf from the stock pack. The ride was softer than the skyjackers and the flex was good. I opted not to use the stock leaf or overload, instead I used the downey prerunner add a leaf as the overload and achieved somewhere in teh neighborhood of 2" of lift.
Now I run Deavers that require relocating the mounts. It was waaaay more than worth it. If yopu're looking for a lot of flex or ride quality, you are limited with the stock length choices. BUt you can get the height you desire.
__________________
IFS IS FOR LOSERS
deathrunner is offline
Old 09-28-2006, 10:41 PM   #4 (permalink)
Gravel Maker's Avatar
Move 'em
and be happy.....easy decision, not expensive.....
__________________
Dan Fredrickson
916.600.1945
www.ruffstuffspecialties.com
Register on our Website for Free Stickers & Member Specials
Gravel Maker is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
rear leaf spring conversion/shock hoop question geTBeNt2NIghT The Fab Shop 7 04-24-2007 10:16 AM
2nd gen vs. 3rd gen rear spring question Stegall984R 95.5-2004 Tacomas & 96-2002 4Runners 1 02-24-2005 03:30 PM
Rancho rear spring question? Extremesolo 95.5-2004 Tacomas & 96-2002 4Runners 1 02-21-2005 10:43 AM
Rear spring question 87 runner Extremesolo 95.5-2004 Tacomas & 96-2002 4Runners 2 01-31-2005 06:14 PM
Rear spring install question tallboy 95.5-2004 Tacomas & 96-2002 4Runners 0 02-23-2004 05:50 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
