Rear end shimmy - 3rd Gen 4Runner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-10-2005, 07:17 PM   #1 (permalink)
22re-efer's Avatar
Talking Rear end shimmy - 3rd Gen 4Runner
Hey everybody, first post. Been checking out the sight regularly, though. I have a question about 3rd gen 4runners. I have a '96 SR5, with stock coils (Toyota replacements in the rear) and original struts in the front and Monroe Reflex shocks in the rear. I recently did a lot of high speed driving on some rough forest service roads and I found that the truck has a scary tendency to have the ass end shift over to the right out of the blue, which I find to be a bit of a problem to say the least. Is this a common problem with the 4runners? Is my only answer to just slow down, or does anybody have some advice as to how I can fix this? Would new struts up front help this? I have a set of OME 890 coils, but I don't really want to raise the center of gravity on the truck, as I think this would probably aggravate the problem. Any advice is appreciated. Thanks in advance.
22re-efer is offline
Old 08-10-2005, 07:19 PM   #2 (permalink)
rimpainter.com's Avatar
Mine does that too, and I have 88K miles, bilsteins, and new coils (at 67K miles). My Tacoma also did this at 30K miles. It is the nature of a solid axle.
Were you aired down a little? If not, try airing down a bit, as it seems to help alleviate some rear end wandering.
rimpainter.com is offline
Old 08-10-2005, 07:24 PM   #3 (permalink)
22re-efer's Avatar
Wow, thanks for the quick response. Yeah, I have 31 X 12.50 XTerrains on it and normally I run them at around 40 psi on the street, and they were dropped to about 30 psi last week. For rougher stuff I would drop to about 20psi. Do you think that I should run them lower on the forest service roads?
Old 08-10-2005, 07:28 PM   #4 (permalink)
I usually run around 25psi on washboard desert roads if I can help it. My rear still kicks out at times.
Old 08-10-2005, 07:45 PM   #5 (permalink)
22re-efer's Avatar
I guess slowing down is probably the answer. That's definately the cheapest option, anyway. I'll try airing down a bit more next time. It seems that the coils with solid axle setup is sketchier than my pickups that I have had in the past. If it was more predictable, I could alter my driving style, but it just jumps over sometimes. Sure gets the heart-rate up, when you have big drops over that side!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
help what rear end in 3rd gen 4Runner need limited slip truetrak? sclimited 95.5-2004 Tacomas & 96-2002 4Runners 12 04-04-2007 01:58 PM
4cyl 3rd gen same rear end as 6cyl? bflooks 95.5-2004 Tacomas & 96-2002 4Runners 2 07-18-2006 09:59 AM
2003 4th gen Front end shimmy cervesa33 03+ 4Runner/GX470, & 05+ Tacomas 6 06-13-2005 11:46 AM
3rd Gen Rear End Cebby 95.5-2004 Tacomas & 96-2002 4Runners 6 11-17-2002 02:38 PM
2009 InternetBrands, Inc.
