Rear Axle Newbe ?
Old 05-04-2009, 10:32 AM
MATTSRED's Avatar
Rear Axle Newbe ?
Putting some new leafs but jack and jack stands are not tall enough to reach
the body's frame.... sooo cutting corners i was thinking jacking it from the rear
axle and taking tires off to lower it down to the jack stands under the frame??
To that i would be taking the front tires off too, so its not at a huge slope....
answers much appreciated
Old 05-04-2009, 10:48 AM
Fossilized
Staff
dropzone's Avatar
sounds a little sketchy but will probably work....just be sure to block the front end...and Don't even consider Cinder blocks...
cutting corners when crawling around under a truck is never a good idea.
I have some 2x12's that I have screwed together to help me gain a few inches on my jackstands...the tall jack stands that Harbor freight has are a great investment...
Old 05-04-2009, 11:07 AM
4Crawler's Avatar
That is how I work on my '85 all the time. I also made spacers for under the jack stands to increase their height a few inches. I used some 2x4 wood for the spacers, sized to fit the base of the stand:
Old 05-04-2009, 11:29 AM
MATTSRED's Avatar
The tallest ones at the harbor freight is the 12 tons right?
Old 05-04-2009, 12:16 PM
Fossilized
Staff
dropzone's Avatar
yeah I think so, i had a set but traded them for something should have kept them.
but I think 4Crawler's pic is a good example of using a shorter jackstand with a pyramid style 2x4 riser...just make sure they are nailed/screwed good too...
very cost effective too...buy a couple of 2x4's cheap and go for it..
Good luck..
Old 05-04-2009, 05:25 PM
MATTSRED's Avatar
Thanks now im gonna be off to home depot.
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
colasurdo
07-16-2015 11:32 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Rear Axle Newbe ?
