YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-04-2008, 09:10 AM   #1 (permalink)
cubuff4runner's Avatar
Rear Axle Lengths
I have a 96 4runner that came with an e-locker and abs. I bent the housing this weekend and I am considering getting the trail gear rock assult housing; however I am not 100% clear which shafts are the correct ones. I know that the Tacomas & 4runners had two different lengths, I am getting conflicting info on if it was the e-locker version or the ABS version that made it longer. Trail gear informed me that the housing is exactly 2" longer than the IFS rears. Can somebody help me determine which are the correct ones.
__________________
96' 4Runner
SAS - 87 Waggy 44 Aussie Locker & Alloy Shafts, 63" Chevy Rear Leaf Conversion, Inchworm Dual Crawler, PSC Hydro Assist, FROR Full Floater
Rockfrogs
Pics
cubuff4runner is offline
Sponsored Links
To remove this ad, register today!
Old 08-04-2008, 10:58 AM   #2 (permalink)
tc
tc's Avatar
I assume you're trying to reuse the parts?
Here's the deal - the way your truck is built, and the trails/obstacles you run, you NEED a full floating rear axle. Seriously - you break an axle shaft (especially due to a bent housing) and the bearing will break and the wheel will not stay on. You will be VERY hard pressed to fix this on the trail, and will likely tear up something more expensive or difficult to fix trying to limp out that way.
Long story short - now's your opportunity to upgrade to FF, and you're gonna need new axle shafts for that.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 08-04-2008, 11:11 AM   #3 (permalink)
I have been seriously considering a FF for the past year.. I knew something like this was bound to happen; especially without a single problem/replacement for 4 years; however with needing a new housing I am not sure if I will be purchasing the FF this year.. I do a lot of mild wheeling during hunting season and I want it driveable by then so I am trying to weigh my options and figure out shaft lengths to see if I can possibly reuse my existing shafts untill the end of October and also have them as trail spares when I do upgrade or is the FF kit and similar Tacoma Housing upgrades a different size?
__________________
96' 4Runner
Rockfrogs
Pics
Old 08-04-2008, 11:35 AM   #4 (permalink)
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
E-locker has nothing to do with axle length. They are same length with or without locker.
Difference would be in the ABS.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by Junkers88 View Post
Good lord this thread is like herpes. Everytime I think it's gone there's another outbreak.
Quote:
Originally Posted by Sin91
If i am awake, I am horny; ask Abe!
DeathCougar is online now
Old 08-04-2008, 12:30 PM   #5 (permalink)
Thanks.. Most places sell axles that are for the Tacoma, but there isn't any specifics on size. Are all of the Tacoma rears the same size unlike the 4runner and if so are they the same as the 4runner with ABS or without.
__________________
96' 4Runner
Rockfrogs
Pics
Old 08-04-2008, 12:52 PM   #6 (permalink)
Tacomas and 4Runners use the same axles. All you have to do is match ABS or non. However, you will run into a difference in the backing plates. Tacomas and 4Runners use different backing plates IIRC.
__________________
Old 08-04-2008, 07:26 PM   #7 (permalink)
tc
tc's Avatar
If you need a new housing anyways, why don't you get one built for the FF, then all you need "extra" are the brake parts (but then you get discs, which is an advantage by itself!)
__________________
tc is offline
Old 08-05-2008, 07:04 AM   #8 (permalink)
Quote:
I have just been trying to make sure that the housing that I was looking at is the same setup / length as the FF kit, but I can't get definate answers. I have decided to just pick up a 86-95 IFS rear from a yard and FF it sooner instead of buying a beefed up housing. If I bend the next one with the FF I can get it home and then look into a stronger housing.
__________________
96' 4Runner
Rockfrogs
Pics
Old 08-05-2008, 08:26 AM   #9 (permalink)
tc
tc's Avatar
Well, while you got it out, truss it up a little bit. You have a big advantage in that you know which way the last one bent and can truss specifically to prevent that...
__________________
tc is offline
Old 08-05-2008, 08:42 AM   #10 (permalink)
I ordered some protection for it last night and I plan on trussing it as much as possible where this one bent.
__________________
96' 4Runner
Rockfrogs
Pics
Old 08-05-2008, 08:54 AM   #11 (permalink)
dirtoyboy's Avatar
Quote:
How and where did the housing bend? just curious......
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 08-05-2008, 08:57 AM   #12 (permalink)
Quote:
It bent right at the outside edge of the spring perch. It will be hard to truss there, but I am going to try to add some small gussets from the perch to the tube closest to the tire on the next one.
__________________
96' 4Runner
Rockfrogs
Pics
Old 08-05-2008, 11:46 AM   #13 (permalink)
tc
tc's Avatar
Could you do a triangular brace from the square bearing flange back along the axle?
Might want to give Brian at Front Range a call and talk it over with him - he's great at that stuff! (Of course, he'll probably try to sell you a diamond housing while he's at it)
__________________
tc is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Feeler: Front solid axle and rear 2wd axle thewjsand Axles/Suspensions/Tires/Wheels 2 04-22-2008 06:17 PM
SAS---sort of--Tacoma rear axle (W/ e-locker) to Truck rear axle Trail_Banger Solid Axle Swaps, All Years 6 02-14-2008 08:08 AM
3723035130 Universals & rear axle - Rear axle - Propeller shaft - Center bearing NEW xcmountain80 Misc Stuff (Vehicle Related) 0 12-10-2007 12:54 PM
2wd rear axle vs. 4wd rear axle (newbie warning) fustercluck 86-95 Trucks & 4Runners 3 08-08-2006 03:05 PM
3rd gen 4Runner rear drive shaft lengths---whats yours? Adam F 95.5-2004 Tacomas & 96-2002 4Runners 4 10-29-2005 04:46 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
