Problems with knuckle rebuild
Ok so I am rebuilding the knuckles on my 83 Toyota truck
I got the knuckles done birfield done and to the point I am putting wheel bearings in got the bearings in and torqued the inner bearing and when the spin the rotor and I get about a 1/4 of a turn and it stops then turns 1/4 of a turn the other way in stops/.
its was the studs that low range I included in the kit that replaced the bolts I reused the bolts and its fine. so far I am very unhappy with the kit I bought from low range it is also missing parts.
got it put together and the locking hub does not spin and it says its in the free postion but when I spin the wheel the pinion spins
there is no better quality locking hub than what came on the truck... do both sides fail to go into the lock position? doubtful that they are both defective.
Ok so I got most of the problems solved the pass side is together done and working great the drive side is don't all the way to installing the spindle I totally forgot to order a spindle because the drive side one was toast.
Low range has the cromeoly ones for around 100 but I don't need a cromeoly one nor do I want to spend that mush on a spindle is there anywhere that's sells a stock replacement
