Potential New Adjustable Air Shocks...
Old 06-09-2005, 04:46 PM
  #41
dragr1's Avatar
Originally Posted by ravencr
Well, I haven't fully tested them, but tonight I had them at 120 psi, sitting 3 1/2" higher than stock and 3 1/4" higher than 20 psi, and they flexed all the way until I was about 2" from my bumpstops. I beleive that on a ramp or out the trail they've probably flex right to the bumpstops as normal, which is really weird to me, but I love the extra height they provide, that's for sure. They'd be great for you Brett!
Chris
Yeah, I'm gonna really check those out next time I see you-at the next ride I guess. My hitch weight is about 350 to 400 pounds on the camper. If you get a chance, put them at 120 psi and then hook up your trailer empty and then you and your dad stand on the trailer tongue and see how much sag there is then?
Old 06-09-2005, 04:58 PM
  #42
ravencr's Avatar
I'll do it, but with both of us up there, who's going to take the pictures. I can already tell you with my truck loaded down with a large cooler, another Gott cooler full of water, a 10x17' tent, a large duffel bag full of clothes, two lounge chairs, two 75 lb dogs, both of my toolboxes(about 50 lbs each), a loaded trailer with my 4wheeler and her dirtbike(approx tongue weight only 150 lbs), and two more rubbermaid boxes full of food and gear, it didn't sag at all. In fact I never had it pumped up to 120 psi, just 110 psi and there's no sag at all. Not only that, it's still sitting above level by 1-2" when fully loaded down. I love it! It was such as easy mod to fix my ride quality when towing my bikes. Like I said before, I couldn't break 65 mph before this mod, but now I can drive 75-80 mph comfortably.
Chris
Old 06-09-2005, 06:19 PM
  #43
dragr1's Avatar
Chris
You can drive that fast while towing with no swaybars?
Old 06-09-2005, 06:38 PM
  #44
ravencr's Avatar
Yep! I prefer to drive 75-80, but Kristen doesn't like it, because she's not used to the way it rides. It's fine though, plus once I get the valve that makes them no cross-linked it will ride even better when towing.
Chris
Old 06-09-2005, 06:40 PM
  #45
dragr1's Avatar
Chris
I'm not understanding this cross linked deal? Do you mean that they act as one when linked-more explanation please?
Old 06-09-2005, 07:24 PM
  #46
Guest
oly884's Avatar
The pressure is shared, that way, when one shock is compressed, it forces the other one down. Like he said, there's a valve that way, you can keep them separate when you don't want any sway.
Old 06-10-2005, 02:27 AM
  #47
ravencr's Avatar
Exactly!
Chris
Old 06-10-2005, 05:56 AM
  #48
mt_goat's Avatar
And that's the reason they will flex great on the trails. So if you install a valve to unlink them for the road you will want to open the valve when you go off-road.
Old 06-10-2005, 10:37 AM
  #49
dragr1's Avatar
OK, got it now.
Old 06-10-2005, 10:40 AM
  #50
ravencr's Avatar
OK, got it now.
What's also nice about this setup is that once I get around to redesigning my rear suspension links and shock mounts, I'll still be able to add the additional load carrying ability, even though my shocks will be like this: /\
Chris
Old 06-10-2005, 10:43 AM
  #51
dragr1's Avatar
Were these $70 a pair or each?
Old 06-10-2005, 10:52 AM
  #52
ravencr's Avatar
Yep, for the pair!
Chris
Old 06-10-2005, 11:05 AM
  #53
dragr1's Avatar
Yep, for the pair!
Chris
Where did you get them? Part #?
Old 06-10-2005, 12:25 PM
  #54
Guest
oly884's Avatar
http://www.partsamerica.com/ProductD...rtnumber=MA727
That's the right part number, and also it said to get this too;
http://www.partsamerica.com/ProductD...artnumber=P573
Old 06-10-2005, 12:37 PM
  #55
Unhappy99's Avatar
The very first post here says 'MA700'
Why do you say 'MA727'?
Old 06-10-2005, 12:40 PM
  #56
4-RUNNIN' FREAK's Avatar
Originally Posted by Unhappy99
1999 SR5....Another 'Certified' POS from Karl Malone Toyota
Defective fuel gauge - 'Certified'
Defective brake rotors - 'Certified'
Defective axle seals - 'Certified'
Defective heater diverter - 'Certified'
etc. etc. etc.
Makes me smile . At least I am not the only one with a few problems.
Old 06-10-2005, 12:48 PM
  #57
ravencr's Avatar
That must be the one for the Tacoma's, and mine was for our 4runners.
Chris
Old 06-10-2005, 12:49 PM
  #58
ravencr's Avatar
What is this about?
Chris
Old 06-10-2005, 08:21 PM
  #59
Guest
oly884's Avatar
Chris
Yep, the MA 727's are for tacos.
Old 06-11-2005, 10:36 AM
  #60
yoda-g2's Avatar
Yup, you can see in the link that the 727's have hoops on both ends. Runners need a stud in the top...
Quick Reply: Potential New Adjustable Air Shocks...
