Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Por-15
So I just scored an 83 Toy axle at the local junk yard for $90 complete, so now my question for those of you who have used POR-15 is it worth it, if it scrapes off is it like powdercoat where you are screwed or can you just paint it againlike spray paint. SO POR-15 or Spary paint, any words of wisdom would help
| Sponsored Links |
#2 (permalink) |
you can paint right over it.. just make sure you prep it very good clean all the grease off of it and wipe it down with some lacquer thinner, then paint away if it chips feather it out, and just spot it in. but you shouldn't have a problem with that.
__________________
Dan 84 4runner sr5 Ford 302 T-18 4spd yota t-case yota front and rear both open 37X13.00 boggers 88 4runner 22re 5spd |
#3 (permalink) |
It's just like powdercoat, IMHO. Get a scratch and it will peal. I've spent over $500 on it in my life time with mixed results - and no results good enough to justify the cost.
Instead of cutting corners with this product, sand blast the axle, prime and paint with a good poly. |
#4 (permalink) |
por-15 is a poly and a good one at that. like all paints it will flake if the surface is not prepped right.
__________________
#5 (permalink) | |
Quote:
Like Powder coating, once the surface of the coating is compromised, all heck breaks loose. Water can wick underneath the coating and it can literally rust from inside out. Watched it happen on a couple of vehicles up here. I think there are better ways.... |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| POR-15 Application | AH64ID | General Vehicle Related Topics (Non Year Related) | 15 | 06-03-2006 07:50 PM |
| Por-15 | T78 | 86-95 Trucks & 4Runners | 3 | 03-26-2006 06:05 PM |
| Por-15 | TheDeuce | General Vehicle Related Topics (Non Year Related) | 5 | 03-19-2006 06:15 AM |
| POR-15 and paint question | Metal Wulf | Maintenance & Repair Archives | 4 | 04-30-2005 03:44 PM |
