| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
panhard bar HELP!
__________________
Current 1998 SR5 3.4L 4x4 4runners of the past: 2000 SR5- the wifes beasty The Green Money Pit 1992 4runner Medalist -2.5" susp lift -2in body lift -15 inch Pro comp Rock crawlers -33x12.5 destination MT's -k&n filter more to come with more money..... *update- cost me too much money- now sold* |
#2 (permalink) | |
Sponsoring Vendor
Quote:
I am baffled too. Did you have the rear wheels off the ground when you installed the Pan Hard bracket? I have done several of these but always used OME shocks....(which shouldn't make any difference) and have had no problem with the axle not coming back into alignment. I have always had the wheels off the ground when installing it. Maybe someone else has seen this but I really don't know what it could be. Can you take some pictures so we can see what you are seeing? I'll be anxious to hear the outcome of this.
__________________
Phil Toyota & TRD Parts Wholesale www.FJCruiserOffroad.com www.trdparts4u.com www.toyotapartsales.com Authorized ARB/OldManEmu Dealer Authorized OASIS Air Deflators Dealer |
#3 (permalink) |
is the bracket on backwards? the one in my pro comp kit was put on backwards at first... i'm not sure what the downey one is like though...
__________________
-Mikey- 1993 4Runner ~ TG HD/RUF front | All Pro rear | 37" Krawlers | Marlin UM06s | 12" King 2.5s | 2" air bumps | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | 4xInnovations cage | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | LED rock lights | PIAA superwhites | stereo Polygoats 4-Wheel Drive Club Poly Performance |
#4 (permalink) |
Like I've always said, the panhard bracket does almost nothing when the truck is just sitting there. Do the geometry math, a 2 inch difference in height does practically nothing. Hell, a 5 inch difference still does almost nothing.
I've got a thread somewhere which shows the math and what is physically happening, even with pictures. In short, your axle came like that from the factory. Anyway, the panhard drop doesn't completely cure the driveshaft hitting the gas tank with the 5009s. I still rub a little, I don't really care.
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! |
#5 (permalink) | |
Quote:
__________________
#6 (permalink) |
here are shots from the rear quarter on the tires offset. the passenger is just a little over an inch more than the drivers. also how and where my driveshaft was rubbing a couple weekends ago.
__________________
Current 1998 SR5 3.4L 4x4 4runners of the past: 2000 SR5- the wifes beasty The Green Money Pit 1992 4runner Medalist -2.5" susp lift -2in body lift -15 inch Pro comp Rock crawlers -33x12.5 destination MT's -k&n filter more to come with more money..... *update- cost me too much money- now sold* Last edited by Y2Krunner; 08-10-2005 at 08:03 PM. |
#7 (permalink) | |
Sponsoring Vendor
Quote:
__________________
#8 (permalink) |
Try measuring to somewhere on the frame, the body might not necessarily be bolted on straight. Was your 4runner ever in an accident?
__________________
#9 (permalink) |
no accident's that have ever been reported to the insurance company. After i did the body lift i would have noticed if it sat off center as it was 2 months before i did anything to the suspension. will see what kind of measurement i can get from the frame to the outside of the fender lip.
__________________
Current 1998 SR5 3.4L 4x4 4runners of the past: 2000 SR5- the wifes beasty The Green Money Pit 1992 4runner Medalist -2.5" susp lift -2in body lift -15 inch Pro comp Rock crawlers -33x12.5 destination MT's -k&n filter more to come with more money..... *update- cost me too much money- now sold* Last edited by Y2Krunner; 08-11-2005 at 01:03 PM. |
#10 (permalink) |
also- i had set my torsion bars where i wanted them and had an alignment done. i just measured and the front end is about 3/4" higher than i set it. will it mess with my alignment if i lower it back down to where i had it prior to the alignment? is the CV angle too much now? (pic attached)
__________________
Current 1998 SR5 3.4L 4x4 4runners of the past: 2000 SR5- the wifes beasty The Green Money Pit 1992 4runner Medalist -2.5" susp lift -2in body lift -15 inch Pro comp Rock crawlers -33x12.5 destination MT's -k&n filter more to come with more money..... *update- cost me too much money- now sold* Last edited by Y2Krunner; 08-11-2005 at 01:04 PM. |
#11 (permalink) |
Call Downey Offroad for 3" pan hard rod drop.
It's the right side in the pics. http://home.earthlink.net/~audiorat1.../rearsusp2.jpg
__________________
http://www.angelfire.com/ca6/954runner GOD's Country Best Seen In A 4 Runner. SAS front: lf,ARB,Ml4",Marlin arms, rear: cable elock,APlinks,OEmu860,35MT/R 5spd, 4:1. ..."But officer, that was not an illegal turn, it was just an undocumented turn." |
#12 (permalink) | |
Quote:
__________________
#13 (permalink) |
If your panhard drop looks like the one in Anthony's pic, you have the right one and its installed correctly. Having the minor amount of axle displacement you show in your pic shouldn't stop you from going on that trip. If you are really worried about the driveshaft rubbing, trim away part of the gas tank skid plate. I had to do it and my axle is centered.
#14 (permalink) |
thats the one i do have. the driveshaft was actually rubbing directly on the gas tank a few inches up from the skid plate. i have long since bent the plate outta the way- its the tank im concerned about. whats everyones take on adjusting my torsion bars post alignment?
__________________
#15 (permalink) | |
Quote:
I have never adjusted mine. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| panhard bar? | roadking8633 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 06-09-2007 09:11 AM |
| Panhard Bar | Thrillbilly | Offroad Tech | 4 | 10-02-2005 02:57 PM |
| 2nd gen trac bar/ panhard bar removal | Y2Krunner | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 08-04-2005 02:05 PM |
| New panhard bar | Praufet | The Fab Shop | 5 | 03-26-2005 03:04 AM |
