open diff. gears are the same as TRD locked gears???? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-01-2005, 03:29 PM   #1 (permalink)
byron4's Avatar
i was wondering if a different gear is needed to fit into a TRD rear then a normal open diff. i am contimplating getting the rear E-locker into my second gen. 4runner and dont know if they require different gears. thanks
byron4 is offline
Old 05-01-2005, 05:02 PM   #2 (permalink)
mt_goat's Avatar
Myth Settled: 8.4, V6, 4cyl, ALL 8" - by Brian Ellinger
Quote:
There is a lot of misinformation out there on these diffs we've all got. These post is ment to clear the air, with actual facts and measurements taken, NOT hearsay. 5 diffs, Im concerned with:
4cyl (from 79-95 4cyl rear diffs, fronts in 79-85)
Early V6 from 88-95 rears in V6 trucks, and 86-87 rear trubo trucks
E-locker rear
High pinion front
Rear 8.25 or whatever (non-locking, taco rear diff)
NEWS FLASH, these are ALL 8" ring gears. The early 4cyl, is the weakest, with the smallest bearings, least ribbing, and pathetic carrier.
The early v6, used screw in adjuster for backlash and carrier bearing preload. It has a 4 pinion (better) carrier, bigger bearings, and more casting in the case.
The E-locker rear uses the same exact gear as the early V6 does, 10 bolts, 8" ring gear. The bearings are all the same, except the drivers side carrier bearing is much large for the shift mechanism.
The high pinion, from the front of fj80's are just a high pinion v6, or high pinion e-lock. Bearings are identical with low pinion versions.
Now the MYTH cleared up. The 8.25/8.4, whatever is not. It is a 8" gear. The casting is better still. The carrier bearings are shimmed, rather than screw in adjusters. The ring gear has 12 bolts instead of 10. Also, the carrier bearing caps are connected with "girdles" and are cast as one piece. This diff I will simply call the late model v6. The pinion shaft is larger, the bearings are slightly lager and the casting is beefier than earlier versions. However, THE RING GEAR IS NO LARGER THAN EALIER 8" DIFFS!
Just so you all know what you are dealing with with these axles.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 05-01-2005, 07:23 PM   #3 (permalink)
Flygtenstein's Avatar
Irrelevant.
The gears areall 8", very good.
The diffs are very different.
The answer is you can put the gears you have now, out of the 2nd gen, onto the carrier for the e-locker because they are all V-6 8" diffs and gears.
Now try putting the e-locker into an open Taco diff.
Flygtenstein is offline
Old 05-02-2005, 12:35 PM   #4 (permalink)
mt_goat's Avatar
This may help: http://www.4x4wire.com/toyota/tech/electric_locker/
__________________
~Dale~
mt_goat is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
TRD e-locked diffs with 4.30 gears TACOZILLA Vendor Advertising 0 06-11-2007 09:56 AM
Which Diff Gears to use cweich 86-95 Trucks & 4Runners 5 01-19-2007 04:29 PM
4:30 gears for a TRD Diff? pinkfloyd73 95.5-2004 Tacomas & 96-2002 4Runners 17 10-27-2006 08:57 AM
Diff Gears steveh 86-95 Trucks & 4Runners 8 03-22-2006 10:33 PM
Diff gears question... Keggo Offroad Tech 10 11-17-2005 11:44 PM
2009 InternetBrands, Inc.
