off camber...how far is to far
I know this is gonna depend on a whole slew of things, but in the few times I've been out, I've had a couple spots where I was puckered pretty good. As my truck is my daily driver, I saw a lev-o-gage for $8 so I snatched it up and on Saturday saw it hit 35degrees a number of times.
So, I'm wondering, at what point, generally, should one be worried?
Obviously, the lev-o-gage isn't exactly a high precision instrument either so that's just a guesstimate.
I've done several searchs and can't really find what I'm looking for on here.
Senior Member
Originally Posted by customcruiser
its alot further then the average person thinks
Originally Posted by jacksonpt
Yup... once you crap your pants, you've still got a ways to go - at least that's the case for me.
My cajones are not quite there yet.
It varies truck to truck place to place.
Pure side hills, as in pitching in only one direction, will give you the most chance to think about it and feel it.
When the truck is flexing and all of the sudden drops, you will just get there.
If you have time to look and check the gauge, you can go farther.
If you smell poop or hear crunching metal, it was too far.
I got pretty far up on the right side this past weekend - farther than I'd been before, and things were "interesting". FunRunner was in my right seat and as I looked over to see if she was breathing, it sure looked like she could touch the ground out the window.
I don't have a clinometer mounted so I dunno how far I was. I actually have a tilt-box, but it's just too big and kinda' goofy lookin' to me. So I started working from the words that Flygtenstein said above - "If you're not on your side, you got more room to go".
I actually get more of a pucker going when I get the wheels on the edge of a drop-off. I had one of those happenin' on Sunday as well. Pics will be up tomorrow on my site and over in the "trail rides" area (WA Reiters 3.28.2004)
I've seen a Toyota (sorta) at 70° and perfectly stable. I've also seen some that roll at 40° with not even a breeze to help out. It all depends on the build.
Exactly, it all depends on the conditions and vehicle. I wheel with a guy who can put his zuk at 70* all day long. Hell, saturday we were out and i was riding with him, he actually laid it on the boggers, without the side ever contacting the ground. It was hard as hell to get out the door to take a picture, if i can find it i will post it. After i got out, he actually backed out of it, and tried again. I was actually suspened by the seat belt and o-˟˟˟˟˟ handle, it was pretty cool.
It not the angle you need to be concerned about it, it is the tire grip or lack of that suddenly causes a roll. I have seen a fullsize Bronco end up on it's side cause the bead popped off of some 35s.
I' ve always wanted to get an inclinometer out and jack the rig up to see where it would finally fall over. I've been over 45 degrees more times that I wish I'd been. After 10 years it still scares the crap out of me. Moreso because I have a very springy suspension and one bump in the wrong direction can THROW me over. I went with the Dana 60s to increase strength yet, but I also went with a wider stance and my COG just got way lower. Those axles alone way twice what the Toyota weights. The shipping weight on the front and rear was just under 1000 lbs!
