Need to lower rear of truck...Leaf removal? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-01-2009, 12:10 PM   #1 (permalink)
I searched but could not find anything helpful. I bought All Pro's front a-arms and coilovers and rear leafs a while back. The rear leafs are 3" and the fronts are adjustable. My problem is that I have to crank the front coilovers up so high to match the rear that it rides worse than stock. I also have went thru a set of all pro's "high angle" cv boots in just 6 months (and only off-roading a couple times -very lightly). I have been trying to figure out how to drop the back end down so I can take some of the pressure off of the front. I thought about removing a leaf in the pack but have no idea how much that would drop it down or what it ride like. It is my DD and the heaviest load it ever carries is my dirtbike every once and a while. Does anyone have any ideas/experience with this? Thanks for any help!
Joe
__________________
99 Tacoma 3.4L TRD 33x12.50 Pro Comp Mud Terrains, All Pro Coil Overs (Bilstein) UCA's, 3" All Pro Leafs, 5150 shocks
86 Toyota Reg Cab Short Bed, parts of a 22r, 35x12.50 Mud Terrains, Dual cases, 5.29 gears, Rear spool, Front Detroit, All parts for solid axle swap uninstalled. No time, no motor
CrunchyTaco is offline
Old 09-02-2009, 08:40 AM   #2 (permalink)
anthony1's Avatar
Send a message via AIM to anthony1 Send a message via Yahoo to anthony1
Maybe you should put the stock springs back and do add a leaf instead.
__________________
http://www.angelfire.com/ca6/954runner
GOD's Country Best Seen In A 4 Runner. SAS front: lf,ARB,Ml4",Marlin arms, rear: cable elock,APlinks,OEmu860,35MT/R 5spd, 4:1.
..."But officer, that was not an illegal turn, it was just an undocumented turn."
anthony1 is offline
Old 09-02-2009, 11:12 AM   #3 (permalink)
4Crawler's Avatar
Not familiar with that exact spring pack, but typically, you can pull the 2nd leaf from the bottom to lower things a little bit. This will help the springs settle faster and if they go too low, then add that leaf back in. Also a shorter spring shackle (if you have a longer than stock pair on there now) can lower things as well.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-02-2009, 08:29 PM   #4 (permalink)
I wasn't smart enough to save my original leafs when I switched them out. I moved with them twice and they finally met the dumpster. Also, since I am running 33's I can't go back to the stock height, I just want something between 0-3". Good idea though.
I am thinking removing a leaf is gonna be the only way. I guess I will start from the 2nd from the bottom and see how that works out, thanks! The shackles are stock so I can't shorten them up any. Thanks for the help guys!
Joe
__________________
Tags
86, 87, ga, kennesaw, leaf, lower, lowering, pack, rear, removal, remove, spring, springs, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
