YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-01-2008, 02:09 PM   #1 (permalink)
rlgraham69's Avatar
Need Help!!! steering issues!!!
I have a 1979 yota 8 inches of suspension lift no body lift and I'm running a set of 38.5 gumbos. I went out playing the other day and broke my front driveshaft so I just continued in 2 wheel drive. I hit a mound of dirt and bent the link that connects the two front wheels!( anything I can use to make this stronger or is there something out there that is sold for this issue???) also the arm that drops from the steering box and connects to the drivers front wheel bent! it was home made where can I find one that will be stronger??? any info will help! Thanks,Richard
Please PM with any info. Thanks
rlgraham69 is offline
Sponsored Links
To remove this ad, register today!
Old 06-01-2008, 10:28 PM   #2 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
You can put a hysteer kit on if you don't have it already.
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write...
Blizzard is offline
Old 06-02-2008, 07:09 AM   #3 (permalink)
dirtoyboy's Avatar
Lets see some pics of this 8 inch lift and your steering set up
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 06-02-2008, 09:07 AM   #4 (permalink)
4Crawler's Avatar
If you are stuck on the stock push-pull setup, you can sleeve the tie rod (connects the two wheels together) or maybe get ahold of a tie rod from one of the crossover steering vendors. Use the FJ80 tie rod ends and the heavy DOM tubing tie rod and it'll hold up better. On the drag link, assume you must have a dropped drag link (an S-shaped one). If so, and yours bent more, probably best to replace it and then brace it up with some gussets.
Or pop for a crossover steering kit as mentioned above, that will lift the steering up above the spring and make it nearly bullet proof:
http://www.4crawler.com/4x4/CheapTri...ng/index.shtml
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
13" steering wheel - anyone have driving issues? crowley84 86-95 Trucks & 4Runners 13 10-03-2007 03:45 PM
Steering column issues jfharris_81 Pre 84 Trucks 2 09-10-2007 06:51 PM
Power Steering Issues EvergreenToy Newbie Tech Section 8 08-19-2007 08:53 AM
Steering/Frame clearance issues 808rj Offroad Tech 4 07-01-2006 11:17 PM
4WD Steering Issues rpeAMP 95.5-2004 Tacomas & 96-2002 4Runners 3 09-09-2002 05:15 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
