Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
My new AW shifter
Needed a way to shift my AW, didn't want to buy what was available so I made my own. The first one was using a Omron PLC(Programmable Logic Controller) it worked great, I had switches mounted on the steering wheel.
I got to thinking that since you are only controlling two solenoids the PLC seemed overkill. My first thought was a lever that had notches on a radius to turn micro switches on and off at the right time. Lots of machine time involved with that idea so I moved onto a rod with notches for the micro switches, two aluminum blocks machined that fit together with a Z/S gate pattern on the top. Tada shifter, finished size is 3/4" x 2" x3" long. Mounted in the center console area. Added a separate switch for TC lock up and now no computer needed. Simple and easy to make. ![]() ![]() |
| Sponsored Links |
#2 (permalink) |
where do you connect it to? What was the total cost? How much would you sell one for?
__________________
-Hayes |
#3 (permalink) | |
Quote:
#4 (permalink) |
that's really cool. so you can basically control an A340 much like a tip-tronic setup?
__________________
-Andrew 94 4Runner 3.0 Auto. I got mods |
#5 (permalink) |
Rail Shifter
Yes you can shift your auto, 1-4 with just this unit connected to solenoid wiring from transmission. Very simple and didn't cost a lot to make.
#6 (permalink) |
I didn't see a cost...
__________________
-Hayes |
#7 (permalink) |
#8 (permalink) |
yeah, I missed that completely on the first round.
__________________
-Hayes |
#9 (permalink) |
can someone please explain TC lockup to me?
__________________
-Hayes |
#10 (permalink) |
I searched for this ages ago and I cant remember the results in detail enough to comment on, but there is tonnes of readings and explanations on when to use TC lockup with your overdrive button and such. Use the search words ECT and overdrive ..you should get plenty of reading.
#11 (permalink) |
Lockup
Let me try and feel free to correct me. Readers Digest version: The lockup is the torque converter actually locking directly to the trans thus eliminating slippage and lowering engine rpm. If you could stop with converter locked the engine would stall.
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Shifter Help | tj_trail | 86-95 Trucks & 4Runners | 0 | 06-22-2008 07:14 PM |
| WTB: center wood console from limited 4runner and shifter surround (4wd shifter) wood | neliconcept | Items Wanted | 2 | 10-11-2007 07:03 AM |
| reducing shifter throw? short shifter kit? cut down actual shifter? | dexter | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 08-24-2007 01:32 PM |
| WTB W56 shifter and topshift TCASE SHIFTER | utah | Engine/Tranny/Parts | 2 | 08-05-2007 11:20 AM |
| shifter | 81 TOY | General Vehicle Related Topics (Non Year Related) | 0 | 05-01-2007 09:30 PM |
